HELP WITH TWRP.
  1. shawn0223
    Gingerbread Oct 10, 2014
    shawn0223 , Oct 10, 2014 :
    Not sure if this is in the right category but im having issues backing up with TWRP. havent been able to figure it out over on XDA and was hoping someone here might know something. I'm getting all these errors when trying to backup. I've tried 2.7.10, 2.8.01 official and unofficial. all give the same issue. Here is the post over on XDA. screenshot attached as well
    http://forum.xda-developers.com/show...&postcount=368
    Lunatasian likes this.
  2. shawn0223
    mods can feel free to move this to the appropriate forum if im in the wrong place but i assumed it was related.
  3. Lunatasian
    KitKat Oct 10, 2014
    Lunatasian , Oct 10, 2014 :
    I'm sure @Aaahh could help you with that ;)
  4. kinghanson99
    Honeycomb Oct 10, 2014
    Aaahh likes this.
  5. Aaahh
    Marshmallow Oct 10, 2014
    Aaahh , Oct 10, 2014 :
    Ahahahahba
    Twrp is solo fragmented.
    I have no idea what stat means. Try clearing cache.
  6. arvinmradze
    Ice Cream Sandwich Oct 10, 2014
  7. shawn0223
    i tried everything lol. it wipes data but still gives the error. it wont let me flash another rom. it gives the error on EVERY damn thing i try to do lol. Im backing up my internal SD card now and figured i'd just go back to stock via fastboot. speaking of which, anyone know the command to use to flash the stock image in fastboot? cant find the *****
  8. shawn0223
    ive done m both of these also. still no go. Do you know what command i would use to flash the entire stock image through fastboot?
  9. arvinmradze
    arvinmradze , Oct 10, 2014 :
    Yes. Use this Method then update to 38r after success. Go to recovery hard reset.
  10. Aaahh
    Search how to jump to cm
  11. shawn0223
    i couldnt do ANYTHING in recovery. i went and used this method. got a fuckin working phone now finally lol
  12. shawn0223
    Thank you all for your help. I had never seen that error before either. just said **** it and backed up my internal and went factory lol
  13. Krunal Oza
    Gingerbread Oct 12, 2014
