help via OnePlus 7 Pro T-Mobile
  1. Goonie
    Cupcake May 22, 2020
    Goonie , via OnePlus 7 Pro T-Mobile , May 22, 2020 :
    I bought a unlocked (I'm starting to see that it may have been from TMobile) OnePlus 7 pro but I want to use the oxygen updater and is says my device won't work since it's a carrier exclusive model plus that it's not rooted how or can I fix this?
  2. Artemus.
    Nougat May 23, 2020
    Artemus. , May 23, 2020 :
    Did you buy it refurbished or from a T-Mo store?
  3. Goonie
    Cupcake May 23, 2020
  4. Artemus.
    Nougat May 23, 2020
    How much did you buy it for? If it's the one I'm thinking of, it has a bad ESN.
    Tobikage likes this.
  5. Goonie
  6. Artemus.
    Nougat May 23, 2020
    Link the listing.
  7. Goonie
  8. Artemus.
    Nougat May 23, 2020
  9. Goonie
    Goonie , via OnePlus 7 Pro T-Mobile , May 23, 2020 :
    how would I do that
  10. Artemus.
    Nougat May 23, 2020
  11. Goonie
  12. Artemus.
    Nougat May 23, 2020
    I... guess? I don't know. I recently bought a 7 Pro as well (factory unlocked).
  13. Goonie
    i like being different and OnePlus has some cool boot animations I happen to come across and want to put on instead of the normal boot animation
  14. Artemus.
    Nougat May 23, 2020
    Boot animation? I think you need root for that. I thought you meant fingerprint animation.
  15. Goonie
    I've kept the default setting on that I like that one but thanks for your help
  16. burbigo
  17. Goonie
    Cupcake May 24, 2020
    Goonie , via OnePlus 7 Pro T-Mobile , May 24, 2020 :
    I'm in the process of converting my phone but I guess the msm download tool v4.0 won't work without the guacamole file below it didn't come up but I should have this done tomorrow
  18. Goonie
    Cupcake May 26, 2020
