Help
  1. ronaldorr
    Cupcake Sep 25, 2020
    ronaldorr , Sep 25, 2020 :
    I currently have the OP3T and would like to use my music files as ringtones / alarms. My question about this is: is it possible without root, does anyone have experience with it?
  2. Horsault
    Nougat Moderator Sep 25, 2020
    Horsault , Sep 25, 2020 :
    Move to OP3T support section, where it belongs.
    Please always remind yourself to post in the appropriate section if you want accurate help.
    BTW, the answer is yes, of course.
    KluGe and Tokolozi like this.
  3. Tokolozi
    Nougat Sep 25, 2020
    Tokolozi , Sep 25, 2020 :
    Yes on android it was possible from the very first models.
    an example (not mine and might be outdated)
  4. KluGe
    KitKat Sep 25, 2020
    KluGe , Sep 25, 2020 :
    With android you may use any sound you like as a ringtone WITHOUT rooting your device. I suggest to you: DO NOT ROOT ANY ONEPLUS! Leave it as good as it is!
    I have copied my own .mp3 to the folder Ringtones and use this one.
    It is really easy: In the sounds menu you've just to choose "Ringtone from intern memory" and select your file.
    DONE! :)
    Tokolozi likes this.
  5. Q1558362165617
    Cupcake Sep 26, 2020
    Q1558362165617 , via OnePlus 7 Pro , Sep 26, 2020 :
    I can't seem to send pictures thru my messages - and can't seem to find any information how to correct this - it's a 7 pro model - I've also checked for updates but it's shows I'm up to date
  6. K1577078840362
    Cupcake Oct 5, 2020
  7. Liehjan
    Lollipop Oct 5, 2020
    Liehjan , Oct 5, 2020 :
    Wrong thread my guy!... wrong thread...
