B1601309299883 , via OnePlus 7 , Jan 17, 2021 : My charging port works as a power button whenever I put my phone in charging it automatically restart and the charging port work as a power button the storage is nearly fill ...
Caomhin , via OnePlus 6T , Jan 18, 2021 : If it is restarting the phone when you plug it iit may be an issue with the port on the phone or cable. Try cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully. If this does not fix it, you can either do a Backup of your data and then do a full Erase All Data factory reset. To see if it helps. Or You can use one or more options below to send information back to the OnePlus OOS developers. https://forums.oneplus.com/threads/...uct-suggestions-on-oneplus-community.1002970/ Feedback tool https://forums.oneplus.com/feedback/ You can also contact bughunters@oneplus.com And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details. https://www.oneplus.com/support
