help
Thread Status:
Not open for further replies.
  1. legitcash
    Gingerbread Jul 14, 2014
    legitcash , Jul 14, 2014 :
    Just got an invite and it won't let me check out...I click on the cart and nothing happens,
    EDIT: worked with a PC...thank you!
  2. GallantJR
    Ice Cream Sandwich Jul 14, 2014
    GallantJR , Jul 14, 2014 :
    Using a phone ?
    if yes, some user reported issue about the checkout using a phone !
    Try desktop !
    mahvi likes this.
  3. speechbubble21
    Froyo Jul 14, 2014
  4. televaughn
    Donut Jul 14, 2014
  5. daryxdj
  6. Deactivated User
    Jul 14, 2014
  7. CyberT
  8. legitcash
  9. Zelm
    Cupcake Jul 14, 2014
  10. Salmonfish
    KitKat Jul 14, 2014
    Salmonfish , Jul 14, 2014 :
    That's sad, you should get help from the admin or try to contact their email
    You should do something before your time runs out
    GOOD LUCK!!!!
  11. Solano
    Solano , Jul 14, 2014 :
    you should use a computer to finish this task.
    seems like you use an tablet... maybe some web features are missing
  12. Surge
    Honeycomb Jul 14, 2014
    Xero likes this.
  13. Xero
    Jelly Bean Jul 14, 2014
    legitcash likes this.
  14. GallantJR
    Probably the same issues as the phone try using a desktop !
  15. abboud
    abboud , Jul 14, 2014 :
    dont use phone use computers to cheak out
  16. TiRaNTx
    Jul 14, 2014
  17. deejay01
    KitKat Jul 14, 2014
  18. mcsmarts
    mcsmarts , Jul 14, 2014 :
    LUUUCCKKKYYY, i hope you get it sorted asap
  19. SteffenG
    KitKat Jul 14, 2014
    SteffenG , Jul 14, 2014 :
    I had the same troubles! Had to refresh the page and switch between store and forum a couple times before it let me checkout
  20. shinraz
    shinraz , Jul 14, 2014 :
    You heard bubble, send him your invites.
