Help!
  1. xBioFur
    Honeycomb Apr 15, 2018
    xBioFur , Apr 15, 2018 :
    As you can see i changed my accent color. But it did not changed in the launcher. How can i fix this?
  2. idkwhoiam322
    Nougat Apr 15, 2018
  3. hashmune
    Froyo Apr 15, 2018
    hashmune , Apr 15, 2018 :
    the laucher changes with accent color
  4. Lancelot_69
    Lollipop Apr 15, 2018
    Lancelot_69 , Apr 15, 2018 :
    Most likely you can change it in your launcher but you don't specify which launcher or os you are running. I personally would reboot to see if that corrects it. Have you installed a new app recently
  5. idkwhoiam322
    Nougat Apr 15, 2018
    hashmune, Liehjan and xBioFur like this.
  6. xBioFur
    I already rebooted. Nope i only deleted all themes to make a new clean start. Suddently the accent color of launcher never changed again.
  7. Lancelot_69
    Deleting all themes is what caused it. Check in your launcher, look for themes or colours, find one you like and set it. That should solve the problem.
    xBioFur likes this.
  8. xBioFur
    idkwhoiam322
    He's using a substratum theme, and according to ozone's dev, the launcher is no longer themeable.​
    Can you give me a source of that because i actually can choose the oneplus launcher to install a theme
  9. xBioFur
    I alr3ady did that it changes color but it changes to the standard color that were there before i installed the theme. so as example. when i choose red the launcher changes to blue. blue was the previous color in the launcher
