4
[Submitted] Hidden apps.
  1. B1621029121397
    Donut Dec 28, 2021
    B1621029121397 , Dec 28, 2021 :
    Title Hidden apps.
    Device OnePlus9Pro Software Version LE2123_11.C.38_1380_202112010418
    Topic Suggestion
    Photos
    Feature Needed Background Description Welcome. At first I wanted to ask because I updated to android phone 12 I have a problem. On Android 11 was very easy to enter the hidden applications by spreading your fingers apart. And it was easy to switch them by simply pressing the settings button. But on Android 12. Unfortunately, this feature is not there. It is much more difficult to enter the application and cannot be left on top, to switch them It's very annoying that I can't switch between hidden chat's . Can't you do it simply? Like was in oos11?
    Any other comments
  2. NotSanta
    Donut Jan 22, 2022
    B1615201782527 likes this.
  3. H1623865322234
    Cupcake Jan 22, 2022
    H1623865322234 , via OnePlus 9 , Jan 22, 2022 :
    I understand the current method and adding security but why not just require a pin to access after pinch to zoom. Current method like leaves the number in the box which negates the enhanced security idea.
    Samsung's Knox system offered biometrics for logging into their isolated apps.
  4. F_Jay_DC_seJH
    Donut Jan 24, 2022
    F_Jay_DC_seJH , via OnePlus 9 , Jan 24, 2022 :
    Same disappointment here. Makes me wonder how it got launched.
    edit- in a way that's good for the security. if you want to go back you can use the number pad. press the back space and # and you will be back to the hidden apps.
  5. Jake1164
    Cupcake Jan 24, 2022
    Jake1164 , Jan 24, 2022 :
    Agree this is a total let down compared to what came with phone. Using a pin vs biometrics is a huge step backwards. You cant have more than one app open at a time.
    But honestly, how can you go from biometrics to a pin / code and think that is ok for the users?
  6. #6
