8
Hide Notch Simulated Screen Edge Curve Doesn't Match
  1. TheH0g4n Eclair Jun 13, 2018
    TheH0g4n, Jun 13, 2018 :
    Does anyone else find it odd that the simulated display curve at the top of the screen in "Hide the Notch" mode doesn't match the real curves on the bottom corners of the screen? Just seems like an odd inconsistency when looking at the screen in this mode.
    ashaduri, xz6droid, MikeG247 and 5 others like this.
  2. Anoshirani50 Cupcake Jun 13, 2018
  3. MikeG247 Jelly Bean Jun 13, 2018
    MikeG247, Jun 13, 2018 :
    Please report this to OnePlus using the feedback link below:
    Nezumi_ and Prcko like this.
  4. thetonyclifton Eclair Jun 13, 2018
  5. vwite Honeycomb Jun 13, 2018
    vwite, Jun 13, 2018 :
    I haven't found an app that works properly, most flicker a lot when unlocking the phone or going home or create unresponsive touchscreen at the corners.
    I verified this downloading the app
    "Rounded corners" https://play.google.com/store/apps/details?id=com.thsoft.rounded.corner
    and enabled it, then dialed *#808# and tried the touchscreen test and the corners were indeed not registering the touches on the corners which eventually becomes really annoying because most apps have 3 dots on corner to open menu
  6. Prcko Jelly Bean Jun 13, 2018
    Prcko, Jun 13, 2018 :
    dear commander keen. why do you open new thread? use search and post your comments in existing thread
  7. TheH0g4n Eclair Jun 13, 2018
    Because I did a search and the forums search engine didn't find any similar threads.
  8. TheH0g4n Eclair Jun 13, 2018
    I'm sure that there is, but I would rather see it properly implemented without a 3rd party background service drawing over other apps.
    MikeG247 likes this.
  9. Prcko Jelly Bean Jun 14, 2018
    Prcko, Jun 14, 2018 :
    for example
  10. vwite Honeycomb Jun 14, 2018
    vwite, Jun 14, 2018 :
    please do leave your feedback to oneplus this is really annoying especially on videos. I already dod and they keep saying it is to "maximize area"
    TheH0g4n likes this.
  11. MentalDraco Lollipop Jun 14, 2018
    TheH0g4n and Nezumi_ like this.
  12. Nezumi_ KitKat Jun 14, 2018
    Nezumi_, Jun 14, 2018 :
    report it to the feedback section so that it'll get noticed, i know it could trigger a lot of people's OCD..
    TheH0g4n and vwite like this.
  13. vwite Honeycomb Jun 14, 2018
    I'm triggered lol
    Nezumi_ likes this.
