2
High cpu idle clock speed
  1. Ribu singh
    Froyo Feb 5, 2018
    Ribu singh , Feb 5, 2018 :
    After updating to oreo the idle clock speed of cpu is higher than normal. Is this a software problem. the phone is not able to enter into the sleep mode. it's happening after Oreo update 5.0.3
    arnoutvos and varma.38 like this.
  2. OnePlus_8t
    Jelly Bean Feb 5, 2018
    OnePlus_8t , Feb 5, 2018 :
    maybe it is not idle , how do you know if there is no background process , already that app is a process , and icons on status bar , display on , SIM , volte , headphone
  3. Ribu singh
    Froyo Feb 6, 2018
    Ribu singh , Feb 6, 2018 :
    can you check the same on your device if you have already installed oreo. same result on cpuz and aida64.
  4. OnePlus_8t
    Jelly Bean Feb 6, 2018
    OnePlus_8t , Feb 6, 2018 :
    Ribu singh
    can you check the same on your device if you have already installed oreo. same result on cpuz and aida64.​
    i mean , if the screen on the app opened and others you don't see , means that the phone is not idle
    same here , even the exact numbers
  5. Ribu singh
    Froyo Feb 6, 2018
    saad1957
    same here
    before Oreo the idle speed was 300 MHz for all cores . Still I am not able to understand why the high performance cores ( cores 4-7) are clocked high as they uses more power. i am just saying is it due to the cpu patch they installed.
  6. OnePlus_8t
    Ribu singh
    on oreo the battery is better , i get 10 hrs SOT in average , i did see around 12 hrs of SOT
  7. Ribu singh
    Froyo Feb 6, 2018
    well maybe android just changed the API for accessing the cpu speed and it's showing some estimated valves idk. I agree with you that battery bakup is better in Oreo.
  8. Kishore_Priyadharsan
    Froyo Feb 6, 2018
  9. Hydra Bob
    Marshmallow Feb 6, 2018
    Hydra Bob , Feb 6, 2018 :
    Well in the change logs there's a reference to a CPU patch that prevents certain exploits by restricting access to high precision timers. So if I had to venture an educated guess, I would say it's related to that patch.
    Abhi Dahiya and saad1957 like this.
  10. OnePlus_8t
    you may report that here :
    https://forums.oneplus.net/feedback/
    and see what answer you may get
    Ribu singh likes this.
  11. G_mahapurush__ILut
    Gingerbread Feb 6, 2018
  12. arnoutvos
    Donut Feb 20, 2018
    arnoutvos , Feb 20, 2018 :
    Since the beginning of February I'm running on Open Beta 5 (OnePlus 5). Is there already more information about what the exact patch is, how it affects cpu speed, performance and battery drain?
  13. Ribu singh
    Froyo Feb 20, 2018
    Ribu singh , Feb 20, 2018 :
    this was the reply i got after reporting this bug.
    alogim and arnoutvos like this.
  14. idkwhoiam322
    Nougat Feb 20, 2018
    alogim likes this.
  15. AntStephenson
    Gingerbread Feb 20, 2018
    stark2991_PL likes this.
  16. alogim
    Ice Cream Sandwich Mar 1, 2018
    alogim , Mar 1, 2018 :
    Any news? I am on Open Beta 3 and the CPU still shows this behaviour.
  17. idkwhoiam322
    Nougat Mar 1, 2018
    idkwhoiam322 , Mar 1, 2018 :
    I did ask them again a while ago, they said it could be something caf merged for the Jan patches against meltdown, spectre. They aren't sure but it is on their list.
    Hydra Bob and alogim like this.
  18. Axel_Ayala
    Froyo Mar 1, 2018
