[Submitted] high cpu speed while idle
  1. OnePlus_8t
    Jelly Bean Apr 1, 2018
    OnePlus_8t , Apr 1, 2018 :
    cpu speed high while idle , minimum 518 MHz -1900 MHz , temp 35° ( room air-conditioned ) , Probablility of occurance is 100 %.
  2. OnePlus_8t
  3. OnePlus_8t
  4. OnePlus_8t
    Jelly Bean Apr 2, 2018
  5. mipirakass
    Gingerbread Apr 2, 2018
    saad1957 likes this.
  6. OnePlus_8t
    OnePlus_8t , Apr 2, 2018 :
    mipirakas
    This is completely normal. CAF (where oneplus gets their kernel source) bumped the minimum frequencies to 518mhz for the little and 806mhz for the big cluster a couple of months ago. They probably had good reasons to do so so there's nothing to worry about.
    https://source.codeaurora.org/quic/.../?id=fa1df42427fc2c3ba5255d2e8593bb292d8fac55
    thank you , this is not good for the battery , it is not the frequency only , when device idle , frequency reaches 1900 MHz
  7. mipirakass
    mipirakass , Apr 2, 2018 :
    If it impacted battery a lot then CAF wouldn't have made this change. they saw a chance to increase performance without impacting battery too much.
    as for your other problem, i'd say this is due to processes in the background. even when idle, there are constant background processes. i see you have installed whatsapp, telegram, twitter, instagram, snapchat, etc... these all run in the background and can cause the frequency to ramp up.
    but if you're confident that it's not due to that, you can always try to clean flash and check if it's still ramping up as much.
    hope this helps.
  8. OnePlus_8t
    thanks , it is clean flashed , will wait and see , i have reported that and sent logs to OnePlus team.
  9. mipirakass
    alright. hope you get it fixed
