Honor magic 2 smart watch not behaving via OnePlus 7T
  1. mandy5951
    Eclair Oct 14, 2020
    mandy5951 , via OnePlus 7T , Oct 14, 2020 :
    I have honor magic watch 2-7E1. It worked perfectly fine on my oneplus 7t prior to update of the watch to its now available software version 1.0.9.58
    Now the watch will connect but the feature of Bluetooth call /answer on watch won't work. The call gets picked up on the phone itself within the first seconds, when it is connected.
    I have done following things :
    1. Factory reset smart watch.
    2. Reset the Wi-Fi /Bluetooth settings on my op7t.
    3. Cleared the cache of the stock dialler app.
    Nothing would work.
    Then I connected the watch to Op5... Same result.
    Here is the interesting thing :
    Huawei health app and watch works as intended on xiaomi devices with the same software version 1.0.9.58 of the smartwatch os.
    So, there is no problem of the app or the smartwatch, but with the oneplus.
    Plz I need fix for this OP team
    jerome_patel likes this.
  2. jerome_patel
    Cupcake Oct 16, 2020 at 5:23 PM
    jerome_patel , Oct 16, 2020 at 5:23 PM :
    I am actually having this same problem, was trying to connect my OnePlus 6 with honor magic watch 2, everything works good except when I receive a call I don't get a notification on my watch and then I couldn't call using my watch,Big fan of OP, Don't want to change my OnePlus phone. Plz fix it asap
    Edit: got it fixed, turn off the smart answer setting in ear phone mode..
  3. mandy5951
    Eclair Oct 17, 2020 at 2:37 AM
    mandy5951 , via OnePlus 7T , Oct 17, 2020 at 2:37 AM :
    Thanks. I found the setting and turned it off too. Then the watch will ring, only with hang up red button and saying the messege that "too many Bluetooth devices connected. Disconnect some to..."
    While I have only one Bluetooth device paired and that is magic watch.
