[Horizon Light]
  1. Ashish Varghese
    Cupcake Sep 29, 2019
    G1571566854542 likes this.
  2. Deactivated User
    Sep 29, 2019
  3. umartariq
    Gingerbread Sep 29, 2019
  4. MilianDue
    Donut Oct 1, 2019
    MilianDue , Oct 1, 2019 :
    Yepp same here, horizon light not working, and sorry but how should we do a Screenshot of none working horizon light?! its a black screen. not only the horizon light - the screen is also not waking up with new notifications coming in, but its activated in the settings.
    danielaevans and Rowekx like this.
  5. gorenc92
    Donut Oct 1, 2019
    patty24i likes this.
  6. Rowekx
    Froyo Oct 2, 2019
    Rowekx , Oct 2, 2019 :
    Horizon Light is just busted. Same for my login for Flipboard. The only thing showing are email choices. But no login link. For Horizon Light, I don't have animations disabled. Should it be?
  7. gorenc92
    Donut Oct 2, 2019
    gorenc92 , via OnePlus 7 Pro , Oct 2, 2019 :
    it shouldn't be disabled, because horizon light and the selfie camera popup light are tied to animation duratiion
  8. Rowekx
    Froyo Oct 2, 2019
    So then there is something else about Horizon Light. Animation is not disabled and yet, it doesn't work. Maybe OnePlus will work or is working on a fix for the problem. I didn't ask, what phone are you using, what version of the OS does it run and does Horizon Light work for your notifications?
  9. Foggy79
    Gingerbread Oct 3, 2019
    ErikMcCall likes this.
  10. I1513260977262
    Cupcake Oct 3, 2019
    I1513260977262 , Oct 3, 2019 :
    Hi All,
    My Oneplus 7 Pro just got upgraded to Android 10 and since then I see slowness in the phone's response. Initially, the horizon light was working fine until I tried to change the color. I had changed the color to red and locked the phone and waited for the red light to popup but no go. I had restarted the phone and the red light came in for a while and then vanished. At this moment none of the light is showing up. Kindly help.
  11. MaJa1969
    Cupcake Oct 3, 2019
  12. Rowekx
    Froyo Oct 4, 2019
    Rowekx , Oct 4, 2019 :
    I wouldn't worry too much about the early performance in the phone right after the update. Keep using it normally. It took about 3 good days before it was back to its blazing fast self again. But like you, my Horizon Light doesn't work.
    I'm beginning to think Horizon Light was "experimental" and the OnePlus devs simply forgot to remove it.
  13. I1513260977262
    Cupcake Oct 4, 2019
    I1513260977262 , Oct 4, 2019 :
    Hopefully it works as before with new features...
    Rowekx likes this.
  14. Rowekx
    Froyo Oct 4, 2019
    There is a bunch of optimization going on with almost any major update and you will feel it while its going on. Especially if you have a lot of installed apps as I do,
  15. I1513260977262
    Cupcake Oct 4, 2019
    yeah I too have many apps installed...
    V1568963168354 and Rowekx like this.
  16. U1570266359021
    Cupcake Oct 5, 2019
  17. kiwi_cz
    Cupcake Oct 18, 2019
    kiwi_cz , Oct 18, 2019 :
    Hello, I found this (slightly bizarre) hint which help me:
    "Setting/System/Accessibility/Large mouse cursor Turn On ! Bellow remove animation must be off to make it work!!"
  18. Rowekx
    Froyo Oct 19, 2019
    Rowekx , Oct 19, 2019 :
    Maybe it's a regional thing for Horizon Light. Every one of these suggestions say to go to settings, accessibility, Large Mouse Cursor. TURN ON! My phone has "Large Mouse Pointer". Its possible the devs didn't code to one called "Large Mouse Pointer" Which is probably why Horizon Light never enables.
  19. Rowekx
    Froyo Oct 20, 2019
    Rowekx , Oct 20, 2019 :
    Ok, for the first time, Horizon Light worked. I did what what suggested above again but this time, I turned OFF animation. (Whew, if you want to see what 90 MHz looks like on Steroids, Turn off animation. Wow). But I like the animation and went in and turn animation back on. That was all I did. I got a message while talking on the phone and BOOM there it was. Horizon Light. I think that might be a trigger on my OnePlus 7 Pro. Whatever it was, its now working
  20. G1571566854542
    Cupcake Oct 20, 2019
