3
Horizon light via OnePlus 9 Pro
  1. Bhaskar243
    Froyo Aug 19, 2021
    Bhaskar243 , via OnePlus 9 Pro , Aug 19, 2021 :
    Horizon light not working
    zuzar, dim059 and Y1631735495524 like this.
  2. Akash_Nayak
    Cupcake Sep 25, 2021
    Best Answer
    Akash_Nayak , via OnePlus 9 Pro , Sep 25, 2021 :
    If you selected don't show notification on lock screen then horizon light won't work
    Try This
    Go to settings -> security and lock screen ->
    Beside Screen lock option their is a setting button click it
    -> under notifications on lock screen option select show all notification content
    Amitchaudhari1008 likes this.
  3. Tokolozi
    Most Original Avatar Aug 19, 2021
  4. Bobbie63
    Marshmallow Aug 19, 2021
    Bobbie63 , Aug 19, 2021 :
    You are aware it only lights up once when receiving a notification?
  5. Bhaskar243
    Froyo Aug 19, 2021
    Bobbie63 likes this.
  6. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 19, 2021
    Dresa91 , Aug 19, 2021 :
    Can you please share a screenshot of your settings?
    Caomhin, J4t1np4r3kh, the_o2 and 2 others like this.
  7. the_o2
    OnePlus 9 Series Expert Community Expert Aug 20, 2021
    the_o2 , Aug 20, 2021 :
    Check accessibility settings, might be Remove animations is enabled.
    Caomhin, Bobbie63 and Dresa91 like this.
  8. #7
  9. Srishti Chetry01
    OnePlus Bug Hunter Staff Member Sep 10, 2021
    Srishti Chetry01 , Sep 10, 2021 :
    We may have to check this further and have contacted you through personal conversation.
    Thanks & regards,
    Srishti.
  10. anilanto007
    Cupcake Sep 21, 2021
