horizontal light on oneplua 5 via OnePlus 5
  1. A1514929280445
    Cupcake Jun 25, 2020
  2. Gav_W86
    Starting Point Expert Community Expert Jun 25, 2020
    Gav_W86 , Jun 25, 2020 :
    what do you mean by horizontal lights?
    Do you mean Horizon Light notifications?
    If so, not sure it came to the 5 with Android 10 (don't have one to hand to check), but if it did it would be under Settings > Display > Ambient Display > Horizon Light.
  3. A1514929280445
  4. Gav_W86
    then no, it hasn't been brought to those devices.
  5. Teekar.2023
    Gingerbread Jun 25, 2020
    Teekar.2023 , via OnePlus 5T , Jun 25, 2020 :
    Horizon light is not available for 5 or 5t. Please search before creating redundant threads. Even a simple Google search would have given you your answer right away.
  6. A1514929280445
  7. pablofg1978
    Nougat Head Moderator Jun 25, 2020
    pablofg1978 , Jun 25, 2020 :
    The op5 has a notification led and does not have curved screen.
    There is no reason to have horizon light notification.
    Maybe you can check in the playstore for an app allows you to have it
    the_o2 likes this.
