OxygenOS
How can I flash a stable build on my OP6T running Beta 5?
  1. jaxidian Cupcake Mar 2, 2019
    jaxidian, Mar 2, 2019 :
    I have Beta 5 installed (released a few days ago on Feb 27) and I'm trying to revert back to the latest stable (released on Feb 21). When I try to do a Local Upgrade, it says I cannot because I'm trying to flash an older build.
    So, what are my options other than waiting for a new stable build to be released?
  2. Moin2200 KitKat Mar 2, 2019
    Moin2200, Mar 2, 2019 :
    You can read the instructions on the thread where you downloaded the beta?
    ironass likes this.
  3. jaxidian Cupcake Mar 2, 2019
  4. Jogi5 Ice Cream Sandwich Mar 2, 2019
  5. jaxidian Cupcake Mar 2, 2019
    "Next time you should read carefully what you do, before you do it."
    WTF is this supposed to mean? I'm not allowed to ask a question without passive aggressive insults? I've been in the beta for months - I don't remember all of the steps for contingencies from months ago.
    Thanks for the info on the rollback ROM, I believe that's what I need. But jeez!
  6. jaxidian Cupcake Mar 2, 2019
    After more reading, it looks like that rollback rom doesn't work with the 6T. At this point, the MsmDownloadTool is the only option I'm finding short of contacting OP Support.
  7. ironass KitKat Mar 2, 2019
    Best Answer
    ironass, Mar 2, 2019 :
    See post #20 of OxygenOS Open Beta 13 for the OnePlus 6 and Open Beta 5 for OnePlus 6T
    There is no, "Roll back", firmware for the 6T and waiting for a new stable release won't work either.
    jaxidian likes this.
