How can I turn on airplane mode without switching off WiFi and Bluetooth?
  1. ian.philip
    Honeycomb Jun 5, 2019
    ian.philip , Jun 5, 2019 :
    I have realized this problem when I take flights. I still want to listen to my music while have to turn on the airplane mode before my flight takes off. However, that immediately switched off my WiFi and Bluetooth and disabled my wireless headset. Anyone knows how to only turn on the airplane mode by itself? I know iOS doesn't have this issue. Thanks.
  2. ian.philip
  3. Santi_SAZ
    Gingerbread Jun 5, 2019
    Santi_SAZ , Jun 5, 2019 :
    All Android phones have this behaviour, when you turn airplane mode on, WiFi and Bluetooth goes to off, but you can enable after airplane mode is on
  4. ian.philip
    Yeah, but that will require a re-connection of the wireless headset...
  5. Santi_SAZ
    yes, you will loose few seconds of music
  6. irasivley93
    irasivley93 , Jun 5, 2019 :
    As previously stated there's unfortunately no way of doing it without the phone first disconnecting both Bluetooth and wifi. It's the default nature of Android to sever ALL connections during airplane mode. Just turn them back on afterwards. It can't take more than ten seconds.
    ian.philip likes this.
  7. ian.philip
    yeah, I know I being an ******* here. But a few sec of re-connection make me feel negative. Anyway, I really appreciate your help here. Thanks!
  8. ian.philip
    I think that's what I am going to do.
  9. irasivley93
    Haha I wouldn't have been so negative about it, We are who we are! If little problems are the only problems then I'd venture to say we're getting on pretty well [e]1f601[/e] Good luck, Be excellent!
  10. ian.philip
    Thanks man. I just switched from iOS. I have to say there some details that iOS has done a better job in optimizing them.
    irasivley93 likes this.
  11. irasivley93
    I frequently swap between the two systems and usually tend to have one iPhone and one Android on my person most of the time. I can agree that there are few things that iOS gets right but for the most part I prefer Android for all the things you can do. iOS is a bit too strict for me. I do wish there were a better match for iMessage on android but what can you do o_O
  12. moneytoo
    Donut Jun 5, 2019
    moneytoo , Jun 5, 2019 :
    You can change what radios are toggled when switching airplane mode on/off...
    Code:
    adb shell settings put global airplane_mode_radios "cell"
  13. kidjt94
    Froyo Jun 6, 2019
    kidjt94 , Jun 6, 2019 :
    just turn off WiFi and mobile data. don't use airplane mode then.
    none of the frequencies your phone uses actually interfere with aircraft. in the US at least.
    source: pilot in my family, and I work on network equipment, alongside radio guys.
  14. toastytoast1234
    Marshmallow Jun 6, 2019
    toastytoast1234 , Jun 6, 2019 :
    You had an OP3, and an OP5.
    Huh?
  15. ian.philip
    Honeycomb Jun 6, 2019
    ian.philip , Jun 6, 2019 :
    I can't agree you more. I have some background in aviation too.
  16. ian.philip
    Just to clarify. My last 3 phones are: OP3, OP5 iPhone X. Then I switched back to OP 7 Pro.
  17. ian.philip
    I have to change some configuration file?
  18. mattborkin
    Froyo Jun 6, 2019
    mattborkin , Jun 6, 2019 :
    Wait, the only think left at that point is Cellular data.
    Why don't you just turn off cellular data first?
