How do I connect wired headphones in op9 via OnePlus 9
  1. shaanchimote
    Cupcake Apr 20, 2021
  2. Bobbie63
    Marshmallow Apr 20, 2021
    Best Answer
    Bobbie63 , Apr 20, 2021 :
    Plug it in and if your headset hasn't got a USB C connector get a usbc to (3.5mm) head jack adapter
  3. #3
    shaanchimote likes this.
  4. Tobikage
    Nougat Apr 20, 2021
  5. Bobbie63
    It looks simple but there's still a few steps to go before you reach the end goal. This was just the simplified version.
    the_o2, Caoimhín and Tobikage like this.
  6. shaanchimote
  7. Bobbie63
    Nope, however you can get this adapter in the OnePlus store though for a few bucks.
    Caoimhín likes this.
  8. Liehjan
    Marshmallow Apr 21, 2021
    Liehjan , Apr 21, 2021 :
    If you are going to buy an adapter, buy a original one... I've had a few cheap from China and they all broke.
  9. ajit.sandhu
    Gingerbread Apr 21, 2021
    arun1814kumar@gm likes this.
  10. VarunKacha0801
    Eclair Apr 21, 2021
  11. #12
    ajit.sandhu likes this.
  12. dinamoski
    Gingerbread May 4, 2021
    dinamoski , May 4, 2021 :
    I bought the one plus USB C to 3.5 mm adapter. But it doesn't always recognise it and will play through the phone speakers.
    I have to unplug and re-plug a few times before I get the headset icon.
  13. shahi14323
    Ice Cream Sandwich May 4, 2021
  14. dinamoski
    dinamoski , via OnePlus 9 Pro , May 4, 2021 :
    Yep. Also when I opened the box, the adapter has the thinnest, flimsiest bit of wire on it.
    I was shocked it was a OnePlus product.
  15. #16
  16. dinamoski
    dinamoski , via OnePlus Community App , May 4, 2021 :
    I bought a budget xiaomi as a work phone. It comes with a USB C 3.5mm INCLUDED in the box.
    Also it has DUAL SIM and EXPANDABLE storage...
    The phones was less than £300...
    Also comes with a clear case. Some 9 Pro buyers didn't even get a case.
    It's a bit of a joke you pay so much for a flagship and it doesn't have those features. Not really Pro...
