how do update again to 3.5.6 ?
  1. Chinmay Pawar
    Eclair Apr 4, 2017
  2. Onkar.Singh
    KitKat Apr 4, 2017
    AryanBasam likes this.
  3. Lancelot_69
    Lollipop Apr 4, 2017
  4. G_Chris_Murphy_ymNT
    Eclair Apr 4, 2017
    G_Chris_Murphy_ymNT , Apr 4, 2017 :
    download the update you want from one plus support --> downloads --> op2 and flash it from one plus two's original recovery. to do this turn off the phone and hold down the power and volume up or down button, or go to developer options and check the box that says advanced reboot, then hold the power button and click the reboot and reboot into recocvery mode and then flash from there, it should be labbeled install from local.
  5. Chinmay Pawar
    Eclair Apr 4, 2017
    Chinmay Pawar , Apr 4, 2017 :
    will i loose my data while doing this ?
  6. Chinmay Pawar
    Eclair Apr 4, 2017
    i am on 3.5.6 os now but i am having some issues with it so i have to do the upgrade and installation again to resolve my problem i have herd that works .
  7. pankaj1004
    Donut Apr 5, 2017
    pankaj1004 , Apr 5, 2017 :
    u r data will be safe...in my case i didn't loose my data...but do it carefully
  8. G_Naman_Jain_YXJe
    Cupcake Apr 6, 2017
  9. Chinmay Pawar
    Eclair Apr 10, 2017
  10. SaketGillurkar
    Honeycomb Apr 10, 2017
  11. jcagara08
    Gingerbread Apr 10, 2017
    jcagara08 , Apr 10, 2017 :
    downgrade him to rock level or let him reincarnate to a fly
    Lancelot_69 likes this.
