4
How do you capture a screenshot on One Plus
  1. Deactivated User
    Mar 16, 2015
    pbergonzi likes this.
  2. ProWeb
    Donut Mar 16, 2015
    ProWeb , Mar 16, 2015 :
    I'm shocked at my inability to get the PowerButton + Volume Down screenshot to work on my 2-day old OPO!?!?
    I've tried about 100 different ways and none of them grab the screen. Holding down the power button and choosing screenshot works just fine... just not the button combo option. :(
  3. Teresa loizos
    Honeycomb Mar 16, 2015
    Teresa loizos , Mar 16, 2015 :
    Just press the power button and from the menu choose screenshot. All done ;)
    Sorry I read just the first part of your post :rolleyes:
    Ceasedd likes this.
  4. Iesha Sharma
    Cupcake Mar 31, 2015
    Iesha Sharma , Mar 31, 2015 :
    • Hold the Power button and Volume Down button of your OnePlus One smartphone at the same time.
    • Keep holding for 3-4 seconds until you see that a screenshot has been taken.
    • One the screenshot has been taken you can go to the Notifications Area and see the Screenshot. From there you can also send the screenshot to anyone using Facebook, Gmail, What’s App etc.
  5. tuga49
    Ice Cream Sandwich Mar 31, 2015
    tuga49 , Mar 31, 2015 :
    power + volume down or in options, you can enable it to power menu, and simple press power menu, and choose screen capture ;)
  6. goldenstang
    Donut Apr 14, 2015
  7. pbergonzi
    KitKat Apr 14, 2015
    pbergonzi , Apr 14, 2015 :
    "...Off!"
  8. brian2012
    Froyo Apr 14, 2015
    brian2012 , Apr 14, 2015 :
    Push the power and volume down buttons at the same time.
  9. Cyberdude
    Honeycomb Apr 14, 2015
  10. Cyberdude
    brian2012 likes this.
  11. i5xswipe
    Ice Cream Sandwich Apr 14, 2015
    i5xswipe , Apr 14, 2015 :
    This is correct, there is also a setting to customize the long-press of the power button to enable screenshot.
  12. brian2012
    Froyo Apr 14, 2015
    Or you could buy another oneplus one to take a picture of your screen. The resolution will be much better.
  13. Cyberdude
    Cyberdude , Apr 14, 2015 :
    nah, you'd be far better off buying an iphone 6, Sam S6 or HTC M9 if you want a good picture of your oneplus screen
  14. sixstringer83
    Froyo Apr 23, 2015
  15. safwan0305
    Froyo Apr 23, 2015
  16. kmessie
    Eclair May 29, 2015
  17. kmessie
    Eclair May 29, 2015
  18. kmessie
    Eclair May 29, 2015
    kmessie , May 29, 2015 :
    Settings-Buttons-Power menu- and select the Add screenshot option.
    Then long press the power button . In the menu which will appear select screenshot
  19. kmessie
    Eclair May 29, 2015
    Settings-->Buttons-->Power menu-->Add Screenshot
    Then long press the power button and select Screenshot. Screenshot_2015-05-28-20-03-31.png
  20. shaik shameer
    Cupcake Jun 20, 2015
    shaik shameer , Jun 20, 2015 :
    after updating cyn 12.1 we should install a gapps too?
