How does a phone downgrade from 64-bit lollipop to 32-bit Kitkat can hardbrick the device?
  1. 0verlord
    Gingerbread Apr 24, 2015
    0verlord , Apr 24, 2015 :
    Hello all OnePlus Fellows,
    I was looking for something when I found this link on Yu Forums. http://forums.yuplaygod.com/threads/announcing-the-yu-beta-testing-program.6348/
    I'll quote the pertinent part of it :
    "3." is a pity actually. But it is "2." I don't understand. Can anyone explain the reason for such. On some other websites dealing with Yu phone upgrade to Lollipop, they happen to mention the same warning without reasoning. It is a request here. :)
    Note:- I know its not a Yu Forum here. But I'm not asking Yu related help. I'm only asking for the reasoning.
    Bharat droid likes this.
  2. siocnarf13
    Jelly Bean Apr 24, 2015
  3. rs98
    Ice Cream Sandwich Apr 24, 2015
    rs98 , Apr 24, 2015 :
    Yeah 64/32 bit is the processor not software lol idk why they'd write that
  4. prstorero
    prstorero , Apr 24, 2015 :
    Because of a bootloader change. That's the reason for bricking. They obviously have no idea what they're talking about with 32 bit vs 64 bit.
    edit: For some reason I thought this was about Oxygen :p
  5. scrivz69
  6. 0verlord
    But CM 12 also has a different bootloader. I bricked my OPO when I used fastboot zip of CM 12. They could create a fastboot type Lollipop update and so as for Kitkat, if your reasoning is correct.
  7. 0verlord
    I failed to understand what's funny. That I don't know this, or that the warning itself is stupid. I fear both :)
  8. Laamapalmu
    Laamapalmu , Apr 24, 2015 :
    Either the CPU or the Software side is stupid and wont work with each other in 32-bit.
  9. Lingering
  10. prstorero
    Just because it's different doesn't mean it isn't compatible. For some reason I actually thought this was about Oxygen since that's the only cases I've seen with bricking on this device.
  11. jove39
    jove39 , Apr 24, 2015 :
    You should be able to flash kitkat with factory image...not sure why they can't support it.
  12. 0verlord
    More than the support to offer, they in fact mentioned that the device will be hard bricked!
  13. Jedipottsy
    Donut Apr 24, 2015
    Jedipottsy , Apr 24, 2015 :
    The Yu Phone has a snapdragon 615, which is a 64bit chip (totally useless), kitkat doesnt support 64bit, so is 32bit. Lollipop does, so the cm12 update for that device is 64bit. I would suspend they have to flash a certain part of the chip to enable 64bit support on the radio/chipset, which is un-reverseable, therefore not possible to downgrade.
    Just had a thought, the bootloader might be updated to a 64bit version, and in doing so would be unable to boot a 32bit kernel. Not sure why fastboot flashing the previous version wouldnt be possible however....
    0verlord and scrivz69 like this.
  14. scrivz69
  15. mskhalek
    Cupcake Apr 25, 2015
  16. xoqes88
    Jelly Bean Apr 25, 2015
    xoqes88 , Apr 25, 2015 :
    Dude, you created a thread asking exactly the same thing. And it was answered there.
  17. Bharat droid
    Gingerbread Apr 25, 2015
    Bharat droid , Apr 25, 2015 :
    as it was said,,it may brick the device, i think somebody should give it a try... because the guarentee replacement for bricked devices
  18. shoujinz
    Froyo May 1, 2015
    shoujinz , May 1, 2015 :
    Will it brick my phone if I just try to install KitKat as a custom ROM while on the Lollipop?
  19. 0verlord
    Gingerbread May 1, 2015
    0verlord , May 1, 2015 :
    If you flash a fastboot type ROM on OnePlus One, it wouldn't do that. The problem is unique for Yureka device.
    shoujinz likes this.
  20. return.of.octobot
    Jelly Bean May 1, 2015
    return.of.octobot , May 1, 2015 :
    If you have to ask, then probably.
