how does multirom storage work?
  1. frankiecortina
    Ice Cream Sandwich Apr 7, 2015
    frankiecortina , Apr 7, 2015 :
    So when currently, I have two Roms installed. Cm12 today's nightlie for internal and exodus for a secondary. I wish there was a way for the apps to sync realtime instead of all using there own storage.is this possible or am I wishing apon a star ? ( sorry for the bad Disney reference :p) but also , does that mean all my data is basically multiplied by 2 ? Since all the apps are installed twice ?
  2. poodster
    Jelly Bean Apr 7, 2015
    frankiecortina likes this.
  3. Zachsaxe
    Lollipop Apr 7, 2015
    Zachsaxe , Apr 7, 2015 :
    No I don't think so they partition
  4. Pucksurfer
  5. mychaudhry
    Cupcake Apr 7, 2015
  6. frankiecortina
  7. frankiecortina
    TheJames likes this.
  8. Zachsaxe
    I'll give you one then and you better use it
  9. mychaudhry
    Cupcake Apr 7, 2015
  10. Kapitan Nemo
  11. prstorero
    prstorero , Apr 7, 2015 :
    Each data/system are separate for each ROM. There's no way currently for slots to share data. And yes data is pretty much doubled since you have it on two different slots.
  12. frankiecortina
    That's what I thought. I guess it's only good for testing before commiting. Thanks:)
    Kapitan Nemo likes this.
  13. m.pratham
  14. prstorero
    Unless you have 64gb, then you have 3 or 4 ROMs installed at once :p I'm not even sure why I have more than two considering once I get on one, I stay on it for a while unless there's a major issue I can't fix :p I guess it prevents from having to do a clean installation for when I move back to it :)
