6
How I resolved OxygenOS Battery Drain
  1. -Fabione-
    Donut Apr 5, 2015
    -Fabione- , Apr 5, 2015 :
    Hey guys, recently I've installed OxygenOS on my opo and I encountered a little battery drain on my device.
    That's how I resolved it.
    - I've installed Xposed for lollipop (here the XDA thred)
    - Then on the Play Store I've downloaded Amplify Battery Extender that block all the useless wake lock
    - From Xposed I've downloaded AppOps and I turned off "keep awake'' from "Google Play Services" and "Sistem Update"
    Thats all, the battery now seems to be very stable and I don't have battery drain.
    Let me know if this worked for you.
    Gg OxygenOS :D
    Screenshot_2015-04-05-15-26-53.png Screenshot_2015-04-05-15-27-02.png Screenshot_2015-04-05-15-28-06.png Screenshot_2015-04-05-15-28-23.png Screenshot_2015-04-05-15-30-44.png
    Jacqen, jdf, Alextheking1993 and 3 others like this.
  2. JelleZon
    Lollipop Apr 5, 2015
  3. Jasmohit
    Jelly Bean Apr 5, 2015
    Jasmohit , Apr 5, 2015 :
    We know that much stuff bro and there are many threads about it so ....................closing
  4. miizoo
    Gingerbread Apr 5, 2015
    miizoo , Apr 5, 2015 :
    Thanks!
  5. MMC49X
    Honeycomb Apr 5, 2015
    MMC49X , Apr 5, 2015 :
    you need to go through a couple of battery cycles on a fresh install to get a accurate portrait of your battery life
    Kapitan Nemo likes this.
  6. -Fabione-
    Donut Apr 5, 2015
    You're welcome bro :D
    Yes but I've encountered a huge battery drain, and now it's gone.
  7. Kapitan Nemo
    LORENZO_MG and B4kken like this.
  8. -Fabione-
    Donut Apr 5, 2015
    You're welcome my friend :D
  9. Therach
    Cupcake Apr 5, 2015
  10. EpicSwirly
    Apr 5, 2015
    EpicSwirly , Apr 5, 2015 :
    Meaning the google services battery drain?
  11. Shrapnelist
    Shrapnelist , Apr 5, 2015 :
    I've done all that and I'm gonna test it out
    By the way ANYONE THAT WANTS DOUBLE TAP TO SLEEP
    install double tap to sleep module in xposed :D it works flawless
    need root I think yes!
  12. miizoo
    Any tips on how to make Xposed framework work on Oxygen OS? I flashed it trough TWRP and then installed APK, still gives me an error that it's not installed.
  13. kyashwanth.k
    Cupcake Apr 7, 2015
    kyashwanth.k , Apr 7, 2015 :
    i have done the same and it works without any fault...
    miizoo likes this.
  14. lokesh3440
    Honeycomb Apr 7, 2015
    lokesh3440 , Apr 7, 2015 :
    Just download few modules,enable them and restart. There is no problem even it is showing not installed as we are installing it through recovery.
    miizoo likes this.
  15. Jacqen
    Ice Cream Sandwich Apr 7, 2015
    Jacqen , Apr 7, 2015 :
    Man thanks fort this post. I'll tell you if it really works but i hope so !!
    Anyways i discovered a lot of usefull infos. :p
  16. Jacqen
    PS : do we need to set up anything on Battery Amplify Extender ? Or just leave it doing his job ?
    Doesn't it work only on Lock screen bar ? Because I have that kind of module installed but only working on lock screen...
  17. Shrapnelist
    Jelly Bean Apr 7, 2015
    Shrapnelist , Apr 7, 2015 :
    since its very old module. it'll work on lockscreen and homescreen but if you ever swipe your notification down then it wont work. this is cause of lolipop i guess
    it did work if i didnt drag down notifications.
  18. Charmacas
    Gingerbread Apr 7, 2015
  19. pbergonzi
    KitKat Apr 8, 2015
  20. pookachee
    Froyo Apr 8, 2015
