How long will a built in battery last?
  1. oneplusdoc
    Jelly Bean Jun 10, 2014
    oneplusdoc , Jun 10, 2014 :
    Would there be any means the battery could be replaced --albeit long distance from the date of purchase? Any idea?
  2. DragonKing45
    Gingerbread Jun 10, 2014
  3. jida
    Honeycomb Jun 10, 2014
  4. deejay01
    KitKat Jun 10, 2014
    deejay01 , Jun 10, 2014 :
    So far, looks like no on replaceable battery option. I have never had to replace one, but it should be good for a few years with normal use. By that point, you will be wanting a one plus two. ;)
  5. slimgym20
    Ice Cream Sandwich Jun 10, 2014
  6. Melvin Joosten
  7. oneplusdoc
  8. oneplusdoc
    sur and Melvin Joosten like this.
  9. Deactivated User
    Jun 10, 2014
  10. darmin13
    darmin13 , Jun 10, 2014 :
    Think you some of you guys just answered the title without reading what he actually posted afterward :p I believe its been said somewhere way back that you might be able to send the device back to OP to have it changed(at a cost) or just do it yourself and void the warranty.
    oneplusdoc likes this.
  11. strafer
    Lollipop Jun 10, 2014
  12. joao50
    Donut Jun 10, 2014
    joao50 , Jun 10, 2014 :
    Most of us never had to change the battery, so, I gess it will the same with a built in one :)
    Fjodor_NL likes this.
  13. cmd1990
    Froyo Jun 10, 2014
  14. Rytyshy
  15. p51d007
    KitKat Jun 10, 2014
    p51d007 , Jun 10, 2014 :
    About as long as a replaceable battery. Depending on usage, about a day or two.
    Lifetime? About 2 years.
  16. Xenon Computer inc.
  17. nrschoen
    nrschoen , Jun 10, 2014 :
    There will always be a way to replace a component, just takes skills and time. And parts!
  18. jeanxito
    jeanxito , Jun 10, 2014 :
    Finally a good thread.. it will be nice if all with the OPO put their battery stats!
  19. chopchopw
    chopchopw , Jun 10, 2014 :
    should last at full capacity for 1 to 1.5 years (300-500 cycles), after that it slowly decreases capacity till it is completely dead. judging from my and friend's old iphone 4s i would say 3 years of solid normal use. of course there is always the temperature and stuff taken into consideration as well, so that could vary. the opo phone battery looks like it could be changed quiet easily
  20. ShinyMichael
    ShinyMichael , Jun 10, 2014 :
    The fact that the battery is built in doesn't mean that it can't be replaced , it can be just not very easily. If your battery was to break or not hold charge well that doesn't mean you need to buy a new phone as it can be replaced. For some one like me who can fix phones this is no problem I have all the equipment needed.
