9
How many days remaining for marshmallow in one plus x
  1. Bassidon
    Gingerbread May 13, 2016
    Bassidon , May 13, 2016 :
    All oneplus x users, I here to discuss an issue.
    While using FB app and simultaneously listens to music via earphones ( only),when I hit the LIKE button, music stops and then starts again.... please reply if everyone facing this same issue.
  2. Deactivated User
    May 13, 2016
    keval_97 likes this.
  3. mradul5
    mradul5 , May 13, 2016 :
    You should use "metal app" instead of Facebook.. This problem doesn't occur in metal..
  4. njoldersma
    Cupcake May 13, 2016
    njoldersma , May 13, 2016 :
    Hopefully before they release Android N!
  5. Dunnow
    The Lab - OnePlus 6 Reviewer May 13, 2016
    Dunnow , May 13, 2016 :
    Again: device trees and cherry picks. How do you think cyanogenmod works?...
    We should learn to read properly...
  6. Bassidon
    Gingerbread May 14, 2016
    Bassidon , May 14, 2016 :
  7. Bassidon
  8. harshith21
    Froyo May 14, 2016
    harshith21 , May 14, 2016 :
    Go to the settings in your facebook app and disable sounds option for likes and you wont have that issue anymore.
  9. Deactivated User
    May 14, 2016
  10. Bassidon
    I
    I know that but . this is a problem ..oneplus must go through this issue..and fix this.
  11. gajira
    gajira , May 14, 2016 :
    There are wrappers apps which are way better in terms of battery drain and privacy settings such as Folio (pro version rocks), Metal and others. I uninstalled official FB app and I'm living better
  12. naa27
    Ice Cream Sandwich May 14, 2016
    naa27 , May 14, 2016 :
    But wrapper apps like metal do everything fb app does only without the massive battery drain and intrusive, unnecessary permissions.
    I hate the official app, it's awful.
  13. Abhi B
    Abhi B , May 14, 2016 :
    That issue is not phone related its app related Every phone will have that issue so blaming OP for it is senseless
    Just tweak with the sound settings in the Facebook app and that should solve it or just Google how to mute Facebook app media sounds
  14. mradul5
    Gingerbread May 15, 2016
    mradul5 , May 15, 2016 :
    Metal is an alternative for Facebook..
    It consumes less battery than fb app..
    And will also solve your problem
  15. Bassidon
    Bassidon , May 15, 2016 :
    Thanks everyone for your suggestion. I wanna know about the MM update ..when it is going to roll out?
  16. Bassidon
  17. naa27
    Ice Cream Sandwich May 15, 2016
    naa27 , May 15, 2016 :
    Is this some kind of joke?
  18. Bassidon
    What do u mean..just asking about MM update on opx...when it will roll out..
  19. naa27
    Yes. Because it's been asked a million times. OnePlus haven't provided a date, and probably won't until it's very nearly done (if ever).
  20. burnout123
