How to activate VoLTE via OnePlus 7T
  1. Y1589822807116
    Cupcake Apr 15, 2021
    Y1589822807116 , via OnePlus 7T , Apr 15, 2021 :
    I already switched on the settings but i see no VoLTE logo on top. My mother and brother's phone(Samsung and Huawei) have VoLTE on their phone. We are using same internet provider
  2. B_Wrath
    Nougat Apr 15, 2021
    B_Wrath , Apr 15, 2021 :
    You need to contact your network provider. They activate it by number. Sometimes, there will be an issue.
    Caoimhín likes this.
  3. Sam197
    Ice Cream Sandwich Apr 15, 2021
  4. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 15, 2021
    Caoimhín , via OnePlus 6T , Apr 15, 2021 :
    If VoLTE is active but no icon. Open Settings>Display>Status Bar>Icon Manager. And enable VoLTE icon.
    If you can't get VoLTE active, try the following.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
    If you do try the suggestions. Let us know how you get on.
    B_Wrath likes this.
  5. kurmigan
    Eclair Apr 15, 2021
    kurmigan , via OnePlus 7 , Apr 15, 2021 :
    Hi Developer Team,
    Reporting a bug were after updating my OnePlus 7 to Oxygen OS 11 my Vodafone Sim Card known as (VI) india Volte not working.
    Please confirm anyone else facing same issue.
    Please reply on this thread.
    X1618591154456 likes this.
  6. dikoscilator
    Honeycomb Apr 16, 2021
    Artemus. likes this.
  7. akks
    KitKat Apr 16, 2021
    akks , Apr 16, 2021 :
    This is a user forum, not customer support. If you want to convey anything to developer team, use the feedback, instead of creating redundant threads.
  8. Wow Yeah Oneplus 7 pro
    Cupcake Apr 23, 2021
    Wow Yeah Oneplus 7 pro , Apr 23, 2021 :
    I found solution for Oneplus 7 series in youtube.
    The way to activate Volte is only use OnePlusLogKit, EngineerMode. apk and Efs tools in this video.
    It is actually in Japanese, but at least you can find a part of solution because mbm on the comment area is only covering Japanese mobile careers. However, once you get mbm from somewhere for your country, you can leverage the way and the command protocol there. The automated subtitles are not fully covered correctly, but you can somehow understand except some words.
    In addition, it seemed not only myself, but also many others succeeded with Oneplus 7/7t/7pro/7t pro. Recommend you to check replies and comments from other users because these might fill your gap.
  9. X1618591154456
    X1618591154456 , via OnePlus 7T Pro , Apr 23, 2021 :
    Hi I am facing the same issue. Have you got any solution?
