15
[How To] Change Lockscreen Wallpaper
  1. aheuser
    Froyo Apr 4, 2015
    aheuser , Apr 4, 2015 :
    I have seen a few complaints that the Oxygen OS wallpaper will not change. It would not initially for me either, but I figured out how to make it happen. You need to select a different lockscreen wallpaper from among the OnePlus wallpapers. This will change the stock lockscreen wallpaper, and afterward, you should be able to change to a custom image.
  2. LifelessLewis
    Jelly Bean Apr 9, 2015
    LifelessLewis , Apr 9, 2015 :
    Damn, thanks man. Works a treat :D this should've got a lot more recognition.
    aheuser likes this.
  3. iwllbethebest
    Froyo May 3, 2015
    iwllbethebest , May 3, 2015 :
    u can easily set lockscreen wallpaper in OXYGEN OS by goin to photos ..opening the image u want and press the 3 dots at the top right and click set as and then lockscreen wallpaper..its so easy..
    Snehaskashyap and pbergonzi like this.
  4. Takendown
    Jelly Bean May 3, 2015
    Takendown , May 3, 2015 :
    Thank you for sharing this with the OxygenOS community. We appreciate it a lot.
  5. jpsulisz
    Froyo May 4, 2015
  6. Goldenfrog96
    Cupcake Jul 2, 2015
  7. bansalg.20
    Gingerbread Oct 8, 2015
    bansalg.20 , Oct 8, 2015 :
    Hey I am unable to find this option in 3 dots, its showing 'Use As' but the no option to select as 'Lock Screen wallpaper' instead 'Wallpaper'. Please post screen print if possible.
    nilanjangm likes this.
  8. Domeyw
    Domeyw , Oct 8, 2015 :
    same here, there isn't the option "lock screen wallpaper"
    merinakova likes this.
  9. sangeeta11
    Cupcake Oct 8, 2015
  10. gkirko
    Gingerbread Oct 16, 2015
  11. alan5854
    alan5854 , Oct 16, 2015 :
    I can't find anything in my OPT that can change my lock screen wallpaper, it just following the wallpaper!
    Help
  12. Hafiz5635
    Honeycomb Oct 16, 2015
    Hafiz5635 , Oct 16, 2015 :
    R
    Root your opt dude..
  13. Rohan Agrawal
    Cupcake Oct 18, 2015
    Rohan Agrawal , Oct 18, 2015 :
    how to set multiple wallpapers..One for Home Screen and another for Lock Screen in One Plus 2?
  14. Spliffman
    KitKat Oct 31, 2015
    Spliffman , Oct 31, 2015 :
    Dont see that option for Lockscreen Wallpaper
  15. Spliffman
    KitKat Oct 31, 2015
  16. Hafiz5635
    Honeycomb Oct 31, 2015
  17. cypher
    Honeycomb Nov 5, 2015
    cypher , Nov 5, 2015 :
    cannot change hydrogen OS stock wallpaper.. do you know how to do it?
  18. jstepa
    KitKat Nov 5, 2015
    jstepa , Nov 5, 2015 :
    Put the image you want for the lockscreen in data/system/users/0 and name it keyguard_wallpaper
    In order to see those hidden folders, you would need a file browser that can show hidden files and folders. Might need to restart phone (some ROM's).
    pbergonzi likes this.
  19. Hafiz5635
    duvelyonker likes this.
  20. Spliffman
    KitKat Nov 5, 2015
    Spliffman , Nov 5, 2015 :
    OK thanks, I had seen that option I believe. I don't want to change lockscreen that bad to jump through those hoops. It was very easy with CM. Maybe it will be added to Oxygen later. But thanks for your help
