4
How to check Battery health/degradation?
  1. Joyyy
    Jelly Bean May 4, 2016
    Joyyy , May 4, 2016 :
    So I had OPO since June 2015 and used it everyday to this day.
    I'm sure the battery degraded over time but I want to find out the info like what's the current capacity of the battery working left etc if I need to replace it?
    I downloaded Gsam battery monitor but only shows what apps etc are using power but not battery current health?
  2. jokicha
    jokicha , May 4, 2016 :
    theres an app called Battery Info
    https://play.google.com/store/apps/details?id=com.stu.battery&hl=en
    it wont give you a percentage of what your battery health is but it will tell you if the health is good or bad. which is enough information to know whether you need a new battery or not.
    on some android phones you can check by entering *#*#4636#*#* on the dialer to check the battery health but cyanogen has it removed.
    Vinkel, brian1951, Slatter191 and 2 others like this.
  3. imTSS
    KitKat May 4, 2016
    imTSS , May 4, 2016 :
    You can try the app CPU-Z. I think it has it. Don't quite remember it.
    Anyways the time when ur battery automatically goes from 50 to 0 and phone switches off. That's the time to replace.
    brian1951 and Joyyy like this.
  4. Ameha Molla
    Cupcake May 4, 2016
  5. Joyyy
    ********** and instructions to change it you can Google it or look on YouTube
  6. Zoecuddles
    Cupcake May 4, 2016
    Zoecuddles , May 4, 2016 :
    I purchased a battery from ebay, then changed it myself after watching a tutorial on you tube.
  7. Ameha Molla
    Cupcake May 4, 2016
  8. Slatter191
    Lollipop May 5, 2016
  9. imTSS
    KitKat May 5, 2016
    imTSS , May 5, 2016 :
    Better to get it changed at a service center. Though there are tutorials but officially it's not user replaceable.
  10. rajrajpatel2007
    Gingerbread Jun 7, 2017
  11. G_Mohamed_Deen_HOdT
  12. G_Thotakuri_Srinivas_MQb
    Cupcake Jun 8, 2017
  13. elanglois
    Lollipop Jun 8, 2017
  14. elanglois
    elanglois , Jun 8, 2017 :
    You need one special tool to open the case that costs about $2. The battery is less than $10 and changing it takes 15 minutes
  15. rei55wolf
    Cupcake Nov 24, 2017
    rei55wolf , Nov 24, 2017 :
    My Battery does not last for more than 12 hours anymore. The Display is at 50% an makes most of the usage (10%) with Adnroid OS in second (4%) and Android-System in third (3%) place.
    It's "optimized" and the Akku-Info says Health is good.
    Any Ideas?
  16. xxchuckyoufarleysxx
    Eclair Nov 24, 2017
    xxchuckyoufarleysxx , Nov 24, 2017 :
    How about this, just get a new phone! Amazing right?
    After a phone gets more than 3 years old, and it's not a removable battery, it really is time to move on, get a new phone.
    There's a reason that most new phones do not come with a removable battery. Manufacturers would go out of business if all the customers kept their phones for 4+ years!
    shubhamkudtarkar likes this.
  17. disha parchani
    Donut Jan 1, 2018
    disha parchani , Jan 1, 2018 :
    You can check all your Battery Hidden Details with this Battery Health Indicator App.
    Joyyy likes this.
  18. Joyyy
    Jelly Bean Jan 5, 2018
  19. F_Harmeet_Parashar_bRuw
    Cupcake Apr 22, 2019
    F_Harmeet_Parashar_bRuw , Apr 22, 2019 :
    Use a wallpaper that has more dark colour like black and less bright colours.
    Turnoff navigation when not being used
    Don't charge the phone upto 100%
    Don't leave the charging overnight
    Don't play too many games
    Rapid discharge then recharge degrades the battery
