How to check Hidden applications using #***# via OnePlus 8T
  1. HarshSiroya
    Cupcake May 23, 2022
    HarshSiroya , via OnePlus 8T , May 23, 2022 :
    I am not able to find my hidden apps using the above method I have One Plus 8T with Android 12 Version what are the steps to check the hidden application using keypad technique.
  2. thechangingtime
    Ice Cream Sandwich May 23, 2022
    thechangingtime , May 23, 2022 :
    Are you referring to access certain hidden features via dialer codes or are you referring to engineering mode on OnePlus, which requires you to have root access to edit a config file to allow the old dialer code for engineering mode to work. And some of the dialer codes are for other manufacturers and will not work on OnePlus phones.
    J1639069705791 likes this.
  3. cfbielok
    Froyo May 23, 2022
  4. PastaJ
    Froyo May 23, 2022
