How to Clean 6T's Earpiece
  1. TejasDwivedi
    Eclair May 20, 2019
    TejasDwivedi , May 20, 2019 :
    Hello Everyone,
    I am a OnePlus 6T user and I have been using this device from November 6, 2018. From that time to the point there has been a lot of dust accumulation in the earpiece of the device.
    I would request anyone kind enough to provide me with some good solutions for my problem.
    Thanks Everybody
    OnePlus User
    [e]270c[/e]️[e]270c[/e]️
  2. Iulian R.
    Gingerbread May 20, 2019
    Iulian R. , May 20, 2019 :
    There's no easy way to do this, as it theoretically should never come to be a problem. Perhaps take it to a repair center or something if you believe something is wrong with it.
  3. TejasDwivedi
    Eclair May 20, 2019
    ummmm no, actually nothing's wrong it's just that it looks dusty and dirty
  4. Iulian R.
  5. TejasDwivedi
    Eclair May 20, 2019
    nope it's just the surface that I want should look good
  6. Iulian R.
    Ah, then perhaps just use some wet tissues or something idk. If it's dirt it shouldn't matter that much what you clean it with. Just make sure it's not too wet, water in the earpiece can muffle the sound
  7. TejasDwivedi
    Eclair May 20, 2019
    I think there's lint too along with the dust and its inside those holes too
  8. Nick 59
    Marshmallow May 20, 2019
    Nick 59 , May 20, 2019 :
    Any number of ways - cotton bud, toothbrush, blu-tack, mini-vacuum etc just don't go poking anything in there. :)
    Iulian R., Artemus and TejasDwivedi like this.
  9. Iulian R.
    Ah, then it could be slightly more complicated... I'll reach back to you if I find anything. For now wet wipes should work for the surface, again make VERY sure it's not too wet
  10. TejasDwivedi
    Eclair May 20, 2019
    yep ok thank you
  11. TejasDwivedi
    Eclair May 20, 2019
    I think this should work for me
    Nick 59 likes this.
  12. Iulian R.
    TejasDwivedi likes this.
  13. Shield10
    Honeycomb May 21, 2019
