How to clear 'Other' in storage? it's taking up 42GB out of my 64 GB via OnePlus 6
  1. akshitasaini
    Cupcake May 27, 2020
    akshitasaini , via OnePlus 6 , May 27, 2020 :
    it's taking up so much space.
    I have tried to clear everything
    I have tried *#888# method
    I have tried recovery mode clear cache
    I have tried Android/data/file/recycle bin clear method.
    after all that I still have 42GB taking up space
  2. Batman360
    KitKat May 27, 2020
    Batman360 , May 27, 2020 :
    The others is for the apps installed, apps data, system's files and folders, Android updates,etc which are necessary. But this is way to much. Go to file explorer and see what's taking up so much space. Check whatsapp folder for one and rest others to, else connect your device to a computer/laptop and arrange the files/folders in your device according to their memory and check.
    akshitasaini likes this.
  3. akshitasaini
    I checked. there is WhatsApp at top taking up 8GB and others are not even close. Still taking apart major things take up (upper limit) 25GB only. The rest of 25GB idk
  4. Batman360
    KitKat May 27, 2020
    Well out of that 25gb 8-10gb is for the system...so you are left with 15gb of unknown data.
    I would suggest you backup your data and factory reset your device. It would be clean atleast and then you can recover your data from the backup you made and will also remove apps that you don't use but are installed anyways.
    Mr. BG and akshitasaini like this.
  5. Batman360
    KitKat May 27, 2020
    Also you posted this in the wrong section, it should be under OnePlus 6 support section instead of introduce yourself section. Post in the correct section from next time.
  6. akshitasaini
    haha yes. I am aware. they wouldn't allow me to post there. and I am in desperate need of help so I posted anywhere 😅[e]1f602[/e]
    Batman360 likes this.
  7. Mr. BG
    Marshmallow May 27, 2020
    Mr. BG , May 27, 2020 :
    There is a reason for that, mostly to prevent repetitive posts.
    If you use search there is hardly a need for new threads.
  8. akshitasaini
    I know. I even found this kind of post, I still couldn't comment -.- so I resorted to this
