2
How to create folders
  1. JuanL
    KitKat Nov 3, 2014
    JuanL , Nov 3, 2014 :
    If you mean how to on the home screen. Just drag an icon just above the other... it will create the folder right there... If you need more help PM me
  2. prowler8811
    Cupcake Dec 22, 2014
    prowler8811 , Dec 22, 2014 :
    I understood what you asked buddy...but sadly even I am searching for that answer..like either how to create folders or is there an app to get that done...
    Hence I turned up here n didn't know people aren't able to understand such a simple question :/
  3. atck
    Cupcake Dec 28, 2014
    atck , Dec 28, 2014 :
    Guys, am new to OPO. But am wondering why am I unable to move a file from one folder to another within the phone? I have to end up using my laptop to do the transfer. Any idea how to fix this as each time an error message appears?
    Thanks
  4. prowler8811
    Cupcake Jan 1, 2015
    prowler8811 , Jan 1, 2015 :
    What is the error message that u r getting?
    And to move/copy files...
    All you have to do is..."check" the item that u want to move or copy....and go to the destination and open properties menu AND choose "move the selection" or "copy the selection" to the destination...that's how it works in opo...
  5. vuessal
    Donut Jan 12, 2015
    vuessal , Jan 12, 2015 :
    Hi everybody!
    On my Samsung GS3, I was able to create folders in App menu (I mean not on homescreen, but on the tiles menu where you have all the apps); also I could HIDE useless/system apps (without uninstalling them).
    I'm new to OPO, since yesterday, now I see I can't do the same.
    Help.
  6. webpatrick
    Honeycomb Jan 12, 2015
    webpatrick , Jan 12, 2015 :
    Samsung has it's own Launcher/App Drawer, so it has different functionality then the default Launcher/App Drawer on OnePlus One (called Trebuchet). But you can find other Launchers in Play Store, which contain different functionality, maybe some with the same functionality like Samsungs launcher.
    If you installed another launcher, you can set it in Settings.
  7. Rajna
    Cupcake Nov 25, 2015
    Rajna , Nov 25, 2015 :
    Just keep pressing on app shortcut and keep it over the other which u want to keep all in a single folder ..
  8. F_Uturashvili_Gvantsa_rT
    Cupcake Jan 25, 2017
    F_Uturashvili_Gvantsa_rT , Jan 25, 2017 :
    it doesnt work that way in oneplus3T
  9. F1575620378759
    Cupcake Dec 6, 2019
