how to dirty flash?
  1. Luxemberg Nixon X
    Honeycomb Dec 30, 2017
  2. Luxemberg Nixon X
  3. Luxemberg Nixon X
    Luxemberg Nixon X , Dec 30, 2017 :
    im thinking of moving to stable...but there are two option in 3 option in recovery
    a. reset system setting
    b. wipe cache
    c. erase all data (music,video,etc(
  4. Luxemberg Nixon X
  5. darius1988
    KitKat Dec 30, 2017
    darius1988 , Dec 30, 2017 :
    Reset sistem will wipe your apps , wipe cache will wipe cache sistem, internal storage will wipe your personal data like fotos, videos, music. Dirty flash mean wipe cache , factory reset mean reset sistem , full hard reset mean all 3 options.
  6. Luxemberg Nixon X
    if i want to clean flash what should i choose? thx
  7. darius1988
    KitKat Dec 30, 2017
    Well you can chose wipe cache-done, than reset sistem- reboot.
    Remember the apps that you installed will be deleted.
    But why you need a clean install?
  8. Luxemberg Nixon X
    i want to go to stable version from beta
  9. darius1988
    KitKat Dec 30, 2017
    Well if you can I recomend you a full hard reset if you can ( wipe cachd-done, reset sistem-done, internal storage-reboot, update to stable than repeat the steps). That's a clean flash.
    If you want dirty flash than wipe cache-done, reset sistem- reboot ( your personal data will be safe).
  10. Bobbie63
    Marshmallow Dec 30, 2017
    Bobbie63 , Dec 30, 2017 :
    Just wait a couple of days until OOS5.0.1 has been rolled out globally. You'll know if there are severe issues or not and if OP is confident enough over this update.
  11. Luxemberg Nixon X
    sry, what do you mean by internal storage-done?
  12. darius1988
    KitKat Dec 30, 2017
    That's the steps you do , from recovery mode .
