How to Disable flip cover auto lock?
  1. t0nnizi
    Donut Feb 7, 2017
    t0nnizi , Feb 7, 2017 :
    How do I get off the flip cover lock the car? Because I would like to moon about the musics from YouTube, but I can not because the flip cover when you put a stick, so going into the lock. Spotify can about the moon, yes, but there is not much to all the musics found So I want to flip the car cover off the lock, but how to get it?
  2. Mike_van_Esch
    Gingerbread Feb 7, 2017
    ghostofcain and TrippyZ like this.
  3. Bartnl
    Lollipop Feb 7, 2017
    Bartnl , Feb 7, 2017 :
    Hmmmmm..... if I understand this correct spotify and YouTube stop when your flipcover is closed?
    As far as I know there is no setting for this.
    The only way is too keep your flip cover open.
  4. t0nnizi
    Donut Feb 7, 2017
    Spotify will remain on top, and yes even call the flip cover should be closed. But if youtube stop soitamisen side flip cover closed. But where this option is that should it off.
    For example: S5 and S6 and J5 Samsung is at the wheel settings, which can disable this function.
    But where is the OnePlus 3: Sessa this settings?
  5. TrippyZ
    Honeycomb Feb 7, 2017
    TrippyZ , Feb 7, 2017 :
    Can I have some of those drugs that you are on? Pull The Moon!
    mihaelaj and wenna like this.
  6. MadMario123
    Eclair Feb 7, 2017
    MadMario123 , Feb 7, 2017 :
    Spotify keeps playing but Youtube doesn't because it doesn't work with the screen locked, which is what the flip cover does when you close it. I don't think you can affect that.
  7. Mike_van_Esch
    Gingerbread Feb 11, 2017
    Mike_van_Esch , Feb 11, 2017 :
    No screen time out and disable pocket mode?
