How to disable - upcoming alarm notification ?
  1. Fyre
    Cupcake Apr 21, 2018
    Fyre , Apr 21, 2018 :
    You could just use a third party application and dig into its settings and customize to your liking.
  2. RocksOfSteel
    Cupcake Jul 9, 2018
    RocksOfSteel , Jul 9, 2018 :
    Yes, this is pissing me off too. My watch starts vibrating and tells me that my alarm will go off in 2 hours.
    K1542785561195 likes this.
  3. Matluvvw
    Cupcake Aug 23, 2018
  4. M1533723081791
    Cupcake Oct 3, 2018
    M1533723081791 , Oct 3, 2018 :
    Ok i have found solution, just settle alarm and when preliminary nitification pop up put Your finger in notification and hold till You see sign that Notification is switch off... so You will have only alarm.
  5. Y1541116825124
    Cupcake Nov 26, 2018
    Y1541116825124 , Nov 26, 2018 :
    First time posting here, having the same issue as the original user. I had no luck and have downloaded google clock today which does what we want the stock app to do!
    If you aren't committed to the stock app, I recommend the google equivalent. Two images attached show how different the options are in settings. Screenshot_20181127-074430.jpg Screenshot_20181127-074521.jpg Screenshot_20181127-074430.jpg Screenshot_20181127-074521.jpg Screenshot_20181127-074430.jpg Screenshot_20181127-074521.jpg
  6. Sridari_Iyer
    Cupcake Mar 18, 2019
    Sridari_Iyer , Mar 18, 2019 :
    Install another different alarm app... Try galarm or smart alarm clock.. and don't use the inbuilt OnePlus alarm app.
    V1558578479774 likes this.
  7. V1558578479774
    Cupcake May 23, 2019
  8. Param_Jain
    Cupcake Jul 5, 2019
    Param_Jain , Jul 5, 2019 :
    Disable the clock app from oneplus and install google clock app from playstore , did that and its working great
    In my case the alarm was ringing 30 minutes before its actual time (Apparently this is a nougat feature called smart rise which is supposed to wake up the user pleasantly but it is very annoying in reality)
  9. U1561475847835
    Cupcake Jul 19, 2019
    U1561475847835 , Jul 19, 2019 :
  10. U1561475847835
  11. U1561475847835
