2
How to disable vibration on tap to wake on oxygen OS
  1. pa1281
    Eclair Feb 1, 2016
    pa1281 , Feb 1, 2016 :
    For all the Devs out there, Can anyone make a flashable zip or xposed mudule to disable vibration on double tap to wake in oxygen OS.
    If anyone has a workaround ,please suggest .
    LaksOnePlusUs and bahhaziz like this.
  2. gringoboy
    Lollipop Feb 1, 2016
    gringoboy , Feb 1, 2016 :
    Go to Gestures >> Haptic feedback and disable.
  3. pa1281
    Eclair Feb 1, 2016
    I dont see any option .Could u provide a screenshot if possible?
  4. gringoboy
    Bottom option.
    Edit:
    Lol. My bad. This is COS 12. I didn't read properly!
  5. pa1281
    Eclair Feb 1, 2016
  6. satish21114
    Donut Feb 1, 2016
  7. Sinful_Saint
    Ice Cream Sandwich Feb 1, 2016
    Sinful_Saint , Feb 1, 2016 :
    That applies only to the capacitive keys vibration :)
    Sadly , there is no option to disable the lock screen vibration...Cheers!!
    bahhaziz and satish21114 like this.
  8. Henry80
    Henry80 , Feb 1, 2016 :
    I'd like to know as well, maybe someone can give us a hint: e.g. maybe someone knows a way to do it by editing the system files, as I can't find a way to do it by searching in the settings.
    Great ROM by the way, I was pleasantly surprised.
  9. pa1281
    Eclair Feb 1, 2016
    If someone could make a flasable zip or xposed module from CMs gestures to disable haptic feedback ,that might work I think.
  10. ziflin
    Donut Feb 16, 2016
    ziflin , Feb 16, 2016 :
    Would love to see an option for this on OxygenOS/OPO as well. It seems an odd thing to force on people. I'd think the only feedback that's needed is actually seeing the screen turn on.
  11. F_Siddarth_Bramhane_hjsn
    Cupcake Nov 19, 2016
    F_Siddarth_Bramhane_hjsn , Nov 19, 2016 :
    I want to disable the vibration of double tap to wake but I am on oxygen os 3.1.4. so there is no option is gestures to disable haptic feedback
  12. costi_pit2002
    Gingerbread Nov 20, 2016
  13. LaksOnePlusUs
    Cupcake Sep 26, 2019
    LaksOnePlusUs , Sep 26, 2019 :
    Hi,
    I was upgrade the oxygen OS 10 by yesterday and the same issue me also faced.
    please suggest "How to disable vibration on double tap to wake"
