4
how to enable dash charging sound
  1. jsohamm
    Froyo Apr 3, 2018
    Ravi BINAVAT likes this.
  2. wileyc
    Jelly Bean Apr 3, 2018
  3. jsohamm
    Froyo Apr 3, 2018
    jsohamm , Apr 3, 2018 :
    i m not getting the sound
  4. shreyasopeth
    Honeycomb Apr 3, 2018
  5. M@hee
    Eclair Apr 3, 2018
    M@hee , Apr 3, 2018 :
    Sound is active for dash charging but very low. You enable all notification sounds on device.
  6. G_Yuva_R_YjuZ
    Gingerbread Apr 3, 2018
  7. marcusskyfall
    marcusskyfall , Apr 3, 2018 :
    Mine bleeps when lit and also when un lit. So long as it's connected properly :)
  8. AKHAN2257967
    Cupcake Apr 3, 2018
  9. F_Ankit_Sharma_pIZN
    Cupcake Apr 3, 2018
  10. Mr_Cyrox
    KitKat Apr 3, 2018
    Mr_Cyrox , Apr 3, 2018 :
    it only makes sound if you charge you phone while it is locked it doesint play the sound when it is unlocked (on 5.0.4 atliest)
  11. MikhailTheItalian
  12. G_Mateo_DxQd
    G_Mateo_DxQd , Apr 3, 2018 :
    Yes, I noticed too that it wasn't playing anymore. I didn't pay attention if it was because my phone was on silent or that it just stopped sounding
  13. biplabloveu
    Ice Cream Sandwich Apr 3, 2018
    biplabloveu , Apr 3, 2018 :
    There is no settings for it as per I know.
    It will make the click sound or kinda if your phone is in locked condition only. While you're not using it.
    If you're using it or your phone is unlocked and left to home screen then also your phone will do the little double vibration only. No sound.
    If you're locked then it will do the double vibration while plugging and that click sound after a second or 2 when the dash charge begins.
  14. mukulagrawal
    mukulagrawal , Apr 3, 2018 :
    No it still makes the sound mine does
  15. Sam Withaar
    Donut Apr 3, 2018
    Sam Withaar , Apr 3, 2018 :
    funny enough I started getting that beep a while ago, I agree with it being annoying. so no setting?
  16. G_ahmed_idris_ZMIJ
    Donut Apr 3, 2018
  17. Ashishagrawal8
    Donut Apr 3, 2018
    Ashishagrawal8 , Apr 3, 2018 :
    ya..there's a sound when u plug in but my phone also is not making that noise since some time..missing it really
  18. G_Jannick_Vervoorn_udYv
    G_Jannick_Vervoorn_udYv , Apr 3, 2018 :
    you have to put your alert slider down, so you enable Notification sounds, plug your Dash charger in and you Will hear the sound. thread closed / answered
    #38
  19. Hydra Bob
    Marshmallow Apr 3, 2018
    #39
  20. G_Jannick_Vervoorn_udYv
    #40
