how to enable OTG USB on OnePlus 3T
  1. Ramdinpuia
    Honeycomb Feb 22, 2018
    Ramdinpuia , Feb 22, 2018 :
    How does one enable OTG on OnePlus 3T.
    I will mention that it is not there under settings>advanced not storage and memories
  2. BeingIncog
    Nougat Feb 22, 2018
    BeingIncog , Feb 22, 2018 :
    what OOS version you are on?
  3. Ramdinpuia
  4. aquilla
    Gingerbread Feb 22, 2018
    aquilla , Feb 22, 2018 :
    Should be activated by default but you need a special cable not all OTG cables work with OnePlus.
    kunal.h222 likes this.
  5. Sun90
    Starting Point Expert Community Expert Feb 22, 2018
    Sun90 , Feb 22, 2018 :
    It's enabled by default since Nougat.
    The controller for it is present only in open beta builds not official build.
    Just connect the USB device with oneplus compatible OTG cable ( the original oneplus OTG cable is preferable but not mandatory) and see.
  6. Ramdinpuia
    Honeycomb Feb 28, 2018
    Ramdinpuia , Feb 28, 2018 :
    pray do tell where i might get this SPECIAL cable
  7. Sun90
    Starting Point Expert Community Expert Feb 28, 2018
    Sun90 , Feb 28, 2018 :
    OnePlus online stores.
  8. Ramdinpuia
    Any technical change from the usual one?
    For eg. The OTG dongle which came with my Galaxy note 8 works perfectly on the onePlus 5T...
    If someone can shed a light, I think it's one of the biggest problems OnePlus has faced
  9. Paschfire
    KitKat Feb 28, 2018
    Paschfire , Feb 28, 2018 :
    It would need to be compatible with the devices storage specifications.
    The 3T and 5T have different storage specs.
  10. Anshil Ashraf
    Froyo Feb 28, 2018
    Anshil Ashraf , Feb 28, 2018 :
    Amazon basics OTG cable will work
