how to enable voLTE in one plus 7 pro
  1. partha.enigmatic
    Cupcake Jun 15, 2019
  2. B_Wrath
    Nougat Jun 15, 2019
    B_Wrath , Jun 15, 2019 :
    By going into the sim settings.
    otto2 likes this.
  3. partha.enigmatic
    partha.enigmatic , Jun 15, 2019 :
    thank you for the reply..I tried from sim setting but the option is not available
  4. B_Wrath
    Nougat Jun 15, 2019
    Is it enabled by your network provider?
    otto2 likes this.
  5. partha.enigmatic
    yea, because when I used the same sim in different handset, it's appearing. infact, in my old handset OnePlus 3, voLTE was there
  6. B_Wrath
    Nougat Jun 15, 2019
    Can you post a screenshot of the settings?
  7. partha.enigmatic
  8. B_Wrath
    Nougat Jun 15, 2019
  9. partha.enigmatic
    thank you... will do the same.... thanks for your time
  10. U1568781139631
    Cupcake Jun 24, 2020
  11. R.Peter
    Honeycomb Jun 24, 2020
  12. Artemus.
    Nougat Jun 24, 2020
  13. R.Peter
    R.Peter , Jun 24, 2020 :
    Somebody wrote a message yesterday, stating the method worked for him.
  14. Artemus.
    Nougat Jun 24, 2020
    Artemus. , Jun 24, 2020 :
    Did he do the root method or the dialer method?
  15. R.Peter
    I don't know, I saw and read that thread a month ago but because my carrier provides VoLTE by default I didn't have to use it, so I'm not actively following that topic.
  16. Artemus.
    Nougat Jun 24, 2020
    That's the way it should be. Forcing VoLTE on a carrier/plan that doesn't natively support it can have negative effects such as running out of data or incompatibility.
