140
How to get cm updates
  1. jags
    Ice Cream Sandwich Dec 3, 2014
    jags , Dec 3, 2014 :
    thanks for this. I'll add it in the first post.
    I'll check everything as and when I myself get the phone.
    s_vijayganesh likes this.
  2. Jomon
    Gingerbread Dec 4, 2014
  3. jags
    Ice Cream Sandwich Dec 4, 2014
    jags , Dec 4, 2014 :
    Rooting is allowed.
    If you brick your device they'll help.
    Dunno about hard brick
  4. s_vijayganesh
    Eclair Dec 5, 2014
    s_vijayganesh , Dec 5, 2014 :
    Hey I have a doubt , since I've already rooted my phone and the recent new of CM giving OTA, will I be still able to update via OTA?
  5. jags
    Ice Cream Sandwich Dec 5, 2014
    jags , Dec 5, 2014 :
    Yes, you will.
  6. jitesh7
    Cupcake Dec 6, 2014
    jags likes this.
  7. Sandip680
    Gingerbread Dec 8, 2014
    Sandip680 , Dec 8, 2014 :
    Well Cm has clarified now that they wont give Ota updates to the OnePlus One regional devices sold directly in India.. So this means that those buying from amazon will not get the updates... My only query to you is if I flash Cyanogen 44s update from here https://cyngn.com/products/oneplusone/, ie. download the factory image of the software and flash it on my phone, then will I be getting the updates??? I think its the global version CM11s... Please reply???
  8. jags
    Ice Cream Sandwich Dec 8, 2014
    jags , Dec 8, 2014 :
    This can't be confirmed because no one knows yet how they'll block the phone from getting updates.
    We have a global model anyway so I don't know.
    And anyway phone comes with latest 44s installed.
    A new update won't be out before Feb.
  9. Sandip680
    Ok and a final query, if we flash any update with TWRP, will it result in any data loss???If no can you tell me how to do that??:)
  10. jags
    Ice Cream Sandwich Dec 9, 2014
    jags , Dec 9, 2014 :
    Flashing an update won't result in data loss.
    However unlocking bootloader will result in a full format.
    Use google to take a backup prior to this(helium seems to be having issues with the OPO)
    As to how to flash, refer method 2 and the accompanying videos.
    Cheers.
  11. prashantk1985
    Froyo Dec 9, 2014
    prashantk1985 , Dec 9, 2014 :
    Thanks for the information. Will try it on my device. Will get back to you if any issue is there.
  12. Moulie666
    Cupcake Dec 9, 2014
  13. venkyrohan
    Donut Dec 9, 2014
    venkyrohan , Dec 9, 2014 :
    @jags
    Request you to add clarity on below queries. I am a Banker, not much of a software guy. But a tech enthusiast all the way. I have purchased the India version on Amazon and wish to have clarity on below.
    1 How can I manually update OPO to CM12s (assuming that is name of the new custom build for OPO running 5.0)?
    2 Where can I find the requisite files (source)?
    3 The CM app does not work on phones that are already running CM. What are my options here?
    4 Once I install the new version, will I receive OTA updates for future versions/bug fixes released by CM (I am aware CM is very proactive in releasing fixes)? Or would this have to be done manually too? If manual, where will I find the updates and how will I know when one is out?
    Thanks
  14. Sandip680
    Gingerbread Dec 9, 2014
    Sandip680 , Dec 9, 2014 :
    Well my device is rooted so no worrying of unlocking bootloader...Its great if flashing does not wipe data... And ya I am using Titanium Backup Pro so no worrying of backing up data too....
    jags likes this.
  15. Rhitish
    jags likes this.
  16. jags
    Trust I've replied to your PM.
    Let me know if you face any issues
  17. jags
    Around December end (non cm alpha build)
    Jan-feb(stable beta non cm / cm 12s)
  18. BleedMeRed
    Cupcake Dec 10, 2014
  19. jags
    Ice Cream Sandwich Dec 11, 2014
    jags , Dec 11, 2014 :
    I'm sure you can flash the 11s version as well if you can download it.
    This method applies to all cm versions
  20. shkhr_var
    Cupcake Dec 12, 2014
