how to go on open beta 18
  1. Nikhil_H
    Eclair Dec 18, 2017
    Nikhil_H , Dec 18, 2017 :
    hello friends im on open beta 19 and i want to go on open beta 18 coz on ob 19 my phone working too slow, heating too much, battery draining too quick and apps crashing n phone lagging too much, anyone knows the proccess please help, i search this but didnt find
  2. Sun90
    Starting Point Expert Community Expert Dec 18, 2017
    Sun90 , Dec 18, 2017 :
    Why don't you first try a cache wipe in recovery mode and check first.
  3. Nikhil_H
    Eclair Dec 18, 2017
    thanx for ur rply bt i tried everything frnd nothing works
  4. Sun90
    Ok
    Performed a factory reset and seen
  5. Nikhil_H
    Eclair Dec 18, 2017
    i tried wipe cache and data almost format my phone two times, and u mean now i have to go on nought build first and then to ob 18?
  6. Nikhil_H
    Eclair Dec 18, 2017
  7. Sun90
    Since all other workaround have failed for you .
    But you can wait for a cpl of days ,since the next beta update could be available.
  8. Nikhil_H
    Eclair Dec 18, 2017
    are u sure about this?
  9. Sun90
    Sure about what?
    Next update.
    It was supposed to be released by now.
    But heard that it was pulled back before release to public due to some issues ( as quoted by a member here stating that the source of this info is from XDA forum).
    Have tried to boot your phone into safe mode for now and seen if the issue is there too.
  10. darius1988
    KitKat Dec 18, 2017
    darius1988 , Dec 18, 2017 :
    Like sun90 said wait for the next update , will be release this days, or have you tried reflash the beta 19 again ( than wipe cache)?
    Sun90 likes this.
  11. Nikhil_H
    Eclair Dec 18, 2017
    i tried bt not working, please tell me the proccess if u know
  12. Sun90
    You mean the safe mode thing.
  13. Nikhil_H
    Eclair Dec 18, 2017
    i dont know much about that can u help me in this
  14. Sun90
    Safe mode is a debugging mode,if booted into it you can check the stability of the ROM without any influence of the 3rd party apps installed,as they will be disabled in this mode for you.
    You can find a video guide on how to boot OnePlus 3 / 3t into safemode on YouTube.
    Follow it to boot into it and stay in that mode for a battery cycle ( phone call / internet stuff will work for you) and see how the system behaves
    If no issue seen,then it's one of the installed third-party apps causing the issue.which you can rectify.
    If you still find issue here too then it's the ROM that's faulty, you can try reflash of it.
    To get out of Safe mode simply reboot your phone.
  15. Nikhil_H
    Eclair Dec 18, 2017
    thank u frnd let me try this
  16. Nikhil_H
    Eclair Dec 18, 2017
    for how long i hv to stay in safe mode and did i lost any data?
  17. Nikhil_H
    Eclair Dec 20, 2017
  18. ghostofcain
    Marshmallow Dec 20, 2017
    ghostofcain , Dec 20, 2017 :
    To rollback to Oreo builds, just download and update via local update, for nougat just follow the instructions in the OP.
  19. Nikhil_H
    Eclair Dec 20, 2017
  20. ghostofcain
    If you can't construct proper sentences, should you be using a beta build?
    If you continue to experience issues with the beta builds why not raise your issues in the existing beta threads.
