how to go on stable 5.0 from open beta 19
  1. Nikhil_H
    Eclair Dec 1, 2017
    Nikhil_H , Dec 1, 2017 :
    Hi guys i want to know hows performance of stable 5.0, if its good then i want to go from open beta 19 to stable 5.0, and what is the process ??? i searched this thread bt didnt find thats y i create this.
  2. Cosmos_NT
    KitKat Dec 1, 2017
    Cosmos_NT , Dec 1, 2017 :
    check beta thread... first you need to go back to 7.1.1 then update to 8.0
    ghostofcain and Wastted like this.
  3. VaibhavBhargava
    Lollipop Dec 1, 2017
    VaibhavBhargava , Dec 1, 2017 :
    I would recommend you to stay on OPB19 as it is much stable as compared to OOS 5.0
    If you still want to switch to stable branch, I think at this point a simple clean flash should do the trick.
  4. Nikhil_H
    Eclair Dec 1, 2017
  5. Nikhil_H
    Eclair Dec 6, 2017
    Nikhil_H , Dec 6, 2017 :
    what if i want go downgrade to op beta 18 and what is the proccess if i want to go on stable 5.0?
  6. VaibhavBhargava
    Lollipop Dec 6, 2017
    VaibhavBhargava , Dec 6, 2017 :
    You should be able to directly clean flash 5.0 and OPB18.
    It is strange, I wonder why do you want to go back to such builds.
  7. Louistiti8
    Eclair Dec 6, 2017
    Louistiti8 , Dec 6, 2017 :
    OOS 5.0 isn't always stable, i've many few bugs but it's not important, if you like experiment New feature go on 5.0.
  8. Nikhil_H
    Eclair Dec 6, 2017
    becoz after updating to op beta 19 my phones performance is so bad battery is draining too fast compare to op beta 18
  9. Nikhil_H
    Eclair Dec 6, 2017
    r u on oos 5.0?
    Louistiti8 likes this.
  10. VaibhavBhargava
    It's opposite in my case the standby is much better.
    I had to do clean flashes multiple times in the previous builds due to various bugs.
    And for extra security I would recommend that downgrade (clean flash) to the special nougat build (mentioned in the beta thread) and then update to 8.0 via either OTA or local upgrade or flashing.
    Deatham likes this.
  11. Louistiti8
    Eclair Dec 6, 2017
  12. VaibhavBhargava
  13. VaibhavBhargava
  14. Nikhil_H
    Eclair Dec 6, 2017
    did u try that oos (5.0)?
  15. Nikhil_H
    Eclair Dec 6, 2017
  16. VaibhavBhargava
    I don't need to, I have heard enough and its basically an inferior copy of OPB18 (in which i was on previously when the update came out.
    I would rather recommend a factory reset or a clean flash of OPB19, as you have to wipe your data/app's anyways while making the switch.
  17. Nikhil_H
    Eclair Dec 6, 2017
    hmmm let me try this first (clean flash/ factory reset)
  18. Louistiti8
    Eclair Dec 6, 2017
  19. VaibhavBhargava
  20. Deatham
    Ice Cream Sandwich Dec 6, 2017
    Deatham , Dec 6, 2017 :
    I don't know how this, but 5.0 works creamy smooth with great battery life. (unrooted device)
    some people find some builds very stable whereas others find the same build Terrible AF.
    see!
