How to go with slow motion in oneplus 6?
  1. ManojMJ13
    Cupcake May 24, 2018
    ManojMJ13 , May 24, 2018 :
    I have doubt with how to go slow motion in OnePlus 6 camera settings? attaching image with this thread
    OneplusRahul_Chanda likes this.
  2. pablofg1978
    Spanish POC Assistant Head Moderator May 24, 2018
    pablofg1978 , May 24, 2018 :
    Check under video, there should be all the modes to select
  3. ManojMJ13
  4. aditya_malve
  5. nickpetris
    Honeycomb May 24, 2018
  6. pablofg1978
    otto2 likes this.
  7. anvithlobo
    anvithlobo , May 24, 2018 :
    You'll need to update to the latest version for Slowmotion to work so
    Go to Settings>> Update >> check for updates
    you will find a update thats 350+ MB in size download and install it and you'll get the slowmotion option
    otto2 and ManojMJ13 like this.
  8. pablofg1978
  9. aditya_malve
  10. aditya_malve
  11. anvithlobo
    actually it is a bit different we got a separate slowmotion option in the menu
  12. aditya_malve
  13. BillShock
    Gingerbread May 24, 2018
    BillShock , May 24, 2018 :
    I've the same problem with the last OTA of 350mb (18/05/2018)...can anyone explain why?
    EDIT: i've resolved after cleaning data camera app
  14. OnePlus_Rahul
    Cupcake May 30, 2018
  15. Prathvik_Shervegar
    Cupcake Jun 3, 2018
  16. mprfaria
    Cupcake Jun 7, 2018
    mprfaria , Jun 7, 2018 :
    I have the latest OS version and no slow motion option on camera. What's the supposed version of Camera APP that works? I cleared the data on camera app and nothing. Do we need to use another camera app instead of the default?
  17. vichumon
    Cupcake Jul 21, 2018
  18. vaklam2
    Cupcake Aug 13, 2018
    vaklam2 , Aug 13, 2018 :
    I thought this was a problem until I swiped up. More options will appear on the bottom of the screen.
    otto2 likes this.
