How to Hide Call Recorder Notification
  1. R1516683711795
    Cupcake Jan 23, 2018
  2. MakarandMJ
    Gingerbread Jan 23, 2018
    MakarandMJ , Jan 23, 2018 :
    go to Phone> Settings>Auto Record Calls> turn off Auto-Recording notification
    kunal.h222 likes this.
  3. R1516683711795
    R1516683711795 , Jan 23, 2018 :
    I done the same still is showing recording completed
  4. Impels
    Donut Apr 8, 2019
    Impels , Apr 8, 2019 :
    Is there any other option to hide Notification after disconnected the call in Oneplus 6
  5. paulomodesto
    Jelly Bean Apr 10, 2019
  6. _SOMESH_S
    Cupcake May 22, 2019
    _SOMESH_S , May 22, 2019 :
    you can record the calls
    follow the steps u can record it
  7. paulomodesto
    Jelly Bean May 22, 2019
  8. Hydra Bob
    Marshmallow May 22, 2019
    Hydra Bob , May 22, 2019 :
    It's region specific and determined by the SIM card. It can be force enabled through either build prop edits or Magisk module but requires root to be persistent.
    paulomodesto likes this.
  9. A1596978522008
    Cupcake Aug 10, 2020
    A1596978522008 , Aug 10, 2020 :
    Here most of you understood the query wrongly. In One Plus NORD it gives a voice enabled notification"Your call is getting recorded". It can be heard at the other end too. So wanted to know how to disable it....If there is no option to disable the notification/alert when ONE PLUS will fix this issue?
    Sreetico likes this.
  10. H1596098864579
    Cupcake Aug 11, 2020
  11. Prem Jo
    Cupcake Oct 22, 2020
  12. BeardyBiceps
    Ice Cream Sandwich Oct 22, 2020
  13. Madnezz4Ever
    Jelly Bean Oct 22, 2020
    Madnezz4Ever , via OnePlus Community App , Oct 22, 2020 :
    This topic has nothing to do with what you are asking and is posted in the 5T section and not the Nord section.
    As for disabling the "You are being recorded message.", that can't be turned off and there's nothing OnePlus can do about it as the Dialer App is made by Google not OnePlus.
    If you don't want people to know they are being recorded, don't record them in the first place.
    pablofg1978 likes this.
