How to make SD card the default storage in OnePlus X ?
  1. ariblaze
    Jelly Bean Dec 1, 2015
    ariblaze , Dec 1, 2015 :
    Hi All,
    Would like to know how to make the SD card the default storage in OnePlus X ?
    MJTB2011 likes this.
  2. CyberT
    Ice Cream Sandwich Dec 1, 2015
    CyberT , Dec 1, 2015 :
    If you by default mean as default storage to install apps or games that can't be done.
  3. ariblaze
    what about saving pictures, mp3 ?
  4. CyberT
    Sorry but can't help you with that as I don't own an OPX. I read somewhere that in a future update there will be an option to choose default storage location for camera but I don't know if that has come out or not. All the other downloads depends on the app you are using and its settings.
    dinu, Gaurav Rohilla and Tokolozi like this.
  5. Tokolozi
    Most Original Avatar Dec 1, 2015
    Tokolozi , Dec 1, 2015 :
    With a 3rd party camera app this should be possible, and as for mp3, you download these to your device via the pc or directly?
    meatandy and Gaurav Rohilla like this.
  6. Kéno40
    Kéno40 , Dec 1, 2015 :
    For picture, you have to use an other photo app
    FV5 or camera zoom...
  7. billq
    billq , Dec 1, 2015 :
    Dam from the title I thought you'd worked out how to save to the SD card .nope just another thread on previose discussed subject . use the search please in future
    Gaurav Rohilla likes this.
  8. bAvinash097
    Cupcake Dec 1, 2015
    bAvinash097 , Dec 1, 2015 :
    all u have to do is move.
  9. nelsonhknp
    Cupcake Dec 2, 2015
    nelsonhknp , Dec 2, 2015 :
    it seems be bug that do not fix yet to tell camera save your photo into sdcard.
  10. Funk Wizard
    Moderator Moderator Dec 2, 2015
    Funk Wizard , Dec 2, 2015 :
    If u are rooted i have the answer
    meatandy likes this.
  11. niliev84
    Cupcake Dec 2, 2015
    niliev84 , Dec 2, 2015 :
    This is pretty annoying even if you manually move the photos to the SD card then they disappear from the google photos app. If you want to show someone a photo you have to browse to find it as if you are using windows on a laptop.
  12. G_W_C
    Froyo Dec 2, 2015
    G_W_C , Dec 2, 2015 :
    I'm using it with 2.1.3 update, what changed with it is to be able to see the sd card storage in settings-memory, the system is not still able to set main storage to sd card in camera app (default will be internal storage) and also to set the sd card storage as primary storage.
    You can move app (part of the app not the whole app) to sd card when you are in settings-app by selecting every app one by one and see if it is elegible to move something to sd card.
    dinu, Rogel and niliev84 like this.
  13. Goggeboy
    Honeycomb Dec 2, 2015
    Goggeboy , Dec 2, 2015 :
    This is not true, just check Images or Device folders
  14. guisbro
    Ice Cream Sandwich Dec 2, 2015
    guisbro , Dec 2, 2015 :
    FV5 saves to my SD card. Gallery KK searches both sd0 and sd1 for all images and videos.
  15. Rogel
    Cupcake Jan 4, 2016
    Rogel , Jan 4, 2016 :
    Some apps doesn't even work properly when you transfer it to SD card. I hope in the future updates they'll fix this.
    When I transfer apps to SD card, the internal memory stays the same. Nothing changes its suppose to increase available space right.
  16. Noepje
    Froyo Jan 4, 2016
    Noepje , Jan 4, 2016 :
    Does someone know how to move Spotify's storage to the sd card?
  17. shefu
    Honeycomb Jan 4, 2016
    shefu , Jan 4, 2016 :
    Tell me. I'm rooted.
  18. linus98
    Cupcake Jan 4, 2016
    linus98 , Jan 4, 2016 :
    My OPX doesn't read the MicroSD Card. It says, that the SD Card gets prepared and nothing happends.
  19. Kéno40
    Jelly Bean Jan 4, 2016
    SantMS07 likes this.
  20. rjsmuk
    Gingerbread Jan 4, 2016
    rjsmuk , Jan 4, 2016 :
    my opx has an option to save pictures taken to: primary, secondary or browse directory. it's in the settings. i am NOT using the opx camera app, it sux, i am using the PROCAPTURE app.
