How to make volume buttons work like it used to
  1. Aximili
    Cupcake May 2, 2019
    Aximili , May 2, 2019 :
    The volume buttons on my OnePlus 6 used to work really well.
    After an update, it no longer responds immediately.
    It now takes a few seconds of pressing it multiple times until it takes effect.
    (This is really bad when you're at the library and accidentally opened a video or something with a loud sound, you can't turn it down quickly anymore)
    Is there any way to restore it to be responsive again?
  2. Kytharsis
    Marshmallow May 2, 2019
    Kytharsis , May 2, 2019 :
    If you happen to open a video on accident, cover the speaker grill tightly to avoid sound leakage.
    buntycubal likes this.
  3. Roger.T
    Jelly Bean May 2, 2019
    Roger.T , May 2, 2019 :
    It's not allowed in the library anyway, or not?
    Put your phone silently, problem solved...[e]1f601[/e]
    buntycubal and idkwhoiam322 like this.
  4. Treborium
    Cupcake Aug 23, 2019
    Treborium , Aug 23, 2019 :
    That's just poor advice.
    My volume buttons also stopped responding immediately after an update a couple weeks ago.
    I hoped it would be fixed with the next update but it seems it got even worse, to the point where they don't respond at all sometimes and I'm forced to stop whatever media is producing the audio.
    I'm also desperately looking for a fix and am now considering getting a replacement.
    I'd really appreciate any help sine this is a major issue.
    Thanks in advance
