7
How to remove Cellular data limit exceeded notification?
  1. hirakjsaha
    Froyo Jan 13, 2017
    hirakjsaha , Jan 13, 2017 :
    how to restrict background data on cellular network ?... without going to each and every app and restricting it one by one.
  2. F_Swapna_Bakshi_Kale_oWY
    Eclair Jan 13, 2017
  3. naveen.naik254
    Donut Jan 13, 2017
    naveen.naik254 , Jan 13, 2017 :
    Settings <backup&reset<networksettig rest.. U vl lose the saved wifi pwd also n also u can remove the notification
    rohith raj likes this.
  4. naveen.naik254
    Donut Jan 13, 2017
    aswa, Nad23182 and gabush like this.
  5. naveen.naik254
    Donut Jan 13, 2017
    Ya bro but we can get rid of the notification.. Other dn dis do u have any solution dn ur suggestions are appreciated..
  6. gabush
    Donut Jan 13, 2017
    gabush , Jan 13, 2017 :
    Thank you! Worked for me :)
  7. Nad23182
    Cupcake Jan 14, 2017
    Nad23182 , Jan 14, 2017 :
    this worked.. thanks a lot.. :)
  8. rohith89
  9. Necrolyite
    Cupcake Jan 15, 2017
  10. iam_raks
    iam_raks , Jan 15, 2017 :
    Seriously guys.. Am really irritated with that notification... Need new update ASAP... Please guys
  11. alapdaskater
    Ice Cream Sandwich Jan 16, 2017
    alapdaskater , Jan 16, 2017 :
    My problem solved automatically without doing anything. Not sure what happened there.. LOL. Thank you guys for all the inputs. Thumbs up.
    Hope same is the case with all of you!!
  12. Prabhat jaiswal
    Cupcake Jan 16, 2017
  13. MikaelPaul
    Cupcake Jan 17, 2017
    MikaelPaul , Jan 17, 2017 :
    This does seem to be quite the annoying bug. Now, was this a bug that was introduced with 3.5.6 or is this a bug in Android 6.0.1, can anyone confirm? Also where would be the best place to notify the OnePlus team in order to get this resolved in the next patch?
  14. vikram.shah
    Eclair Jan 19, 2017
    vikram.shah , Jan 19, 2017 :
    Network reset worked for me...
    Thanks.
  15. vikram.shah
    Eclair Jan 19, 2017
    Settings > Backup & reset > Network settings reset > select simcard in which you are facing problem > click Reset Settings.
    Confirm and it will be done. Then you can slide data warning notification.
    I am in Oxygen OS 3.5.6
    Myatu likes this.
  16. G_Hancy_Raghav_iiEN
    Cupcake Jan 20, 2017
  17. F_Sanjeev_Gupta_wQtS
  18. Christom
    Donut Jan 24, 2017
    Christom , Jan 24, 2017 :
    Same issue, its very irritating as i have tried all options under the data usage settings... It doesn't even seems OP2 support folks are even taking notice of this bug.....
    #38
  19. chandu0904
    Cupcake Jan 28, 2017
    chandu0904 , Jan 28, 2017 :
    go to settings-data usage-click billing cycle for needed sim.....you have all options there.
    #39
  20. Vishal nagrani
    Cupcake Mar 10, 2017
    #40
