How to remove exclamation mark over signal when data is on
  1. Chathuska
    Gingerbread May 9, 2016
    Chathuska , May 9, 2016 :
    please see the attached images when I on the data or wifi on my OP2 there is an exclamation mark over the signal bar.
    when I off data it will go off... but it is for only one particular network call ETISALAT.
    Please help me. I have posted 2 time about this issue but no one helped me.
      File size:
      279.7 KB
      312
      File size:
      279.2 KB
      285
  2. jkb114
    Lollipop May 9, 2016
    jkb114 , May 9, 2016 :
    Usually the ! means that no actual internet connectivity is being received
  3. Lancelot_69
  4. Chathuska
    But my Internet is working, little bit slower than before.
    and it is only for one network other networks are working fine...
  5. jkb114
    Clear the device cache and reboot. See what happens
  6. Chathuska
    I have reset the device two times... but still problem exist..
  7. Chathuska
  8. Lancelot_69
  9. Lancelot_69
    Lancelot_69 , May 9, 2016 :
    1. Go to "Settings"
    2. Go to "Data Usage"
    3. Go to drop down menu in the upper right hand corner :))
    4. Go to "Cellular Network Settings"
    5. Go to "Access Point Names" (APN's)
    6. Go to the drop-down menu :)) and select
    "Reset to Default"
  10. Chathuska
    Yes APN settings are ok...
    what do u mean "have your carrier as default" ??
  11. Lancelot_69
    That should fix data
    Then go to wifi settings, advanced, then just change the setting, automatic is usually the problem so switch it until the exclamation goes away. 5g the 2g then back to auto
  12. Chathuska
    Done, but problem still remains........ :(
  13. Lancelot_69
    When you go to settings, network settings, Sim card, select network carrier. If you are att select att
  14. Lancelot_69
    OK go to the same place but this time select your carrie/service provider
  15. Chathuska
    where is the wifi settings??
  16. Chathuska
    you mean Network Operator knw??? I selected it but still same
  17. Lancelot_69
  18. Lancelot_69
    Was your network provider listed?
  19. Lancelot_69
  20. Chathuska
    yes it all has failed...
    No i dont use CM, my rom is Oxygen..............
