how to restore notes in OnePlus any device?? urgent
  1. G_RÖÇKSTÀR_GÜRÚÑÃTH_
    Eclair Mar 10, 2019
    rEnthHlei likes this.
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Mar 10, 2019
    Artemus , Mar 10, 2019 :
    Sorry, I don't think this is recoverable as it's meant to be temporary (I believe). Download Google Keep, it's a lot better.
  3. G_RÖÇKSTÀR_GÜRÚÑÃTH_
    Eclair Mar 10, 2019
    G_RÖÇKSTÀR_GÜRÚÑÃTH_ , Mar 10, 2019 :
    TNX buddie
    Artemus likes this.
  4. Varking
    Froyo Mar 10, 2019
    Varking , Mar 10, 2019 :
    Yeah in most cases for note taking Google Keep is great. It syncs really fast as well so you will see changes on your computer or laptop seconds after you make them on your phone. As long as you have access to your account you will have access to your notes :)
    Artemus likes this.
  5. aenews
    KitKat Mar 11, 2019
    aenews , Mar 11, 2019 :
    If there are any actual files, then you could try Diskdigger for recovery. However, I believe the notes are just contained in the application data in this case. Unless you backed up the application data, you're probably SoL. Try using Google Keep and Google Docs in the future to prevent ever losing your notes :)
  6. C1582053465471
    Cupcake Feb 2, 2021
    C1582053465471 , Feb 2, 2021 :
    Login to cloud service and there you will find recycle bin.. and there you go...
  7. sumitMZ007
    Jelly Bean Feb 2, 2021
  8. [email protected]
    Cupcake Nov 26, 2021
    [email protected] , Nov 26, 2021 :
    -I have gone through this problem recently , I deleted the app and installed it again then I have pressed the notes synchronisation available there. I have found all my notes which I have deleted by mistake .(before deleting the notes I did not synchronise them in cloud)
    So do synchronise notes from now !
    After notes are synchronised then you can find those in the "manage cloud storage " in notes.
