3
How to roll back to android 10 on OnePlus 7 Pro from OOS11 open beta 4?
  1. neogodless
    Cupcake May 17, 2021
  2. McJader
    Marshmallow May 17, 2021
    McJader , May 17, 2021 :
    Which device?
    Currently build number?
  3. J1618124028614
    Cupcake May 18, 2021
    J1618124028614 , May 18, 2021 :
    Questions:
    1. Does this method factory reset the phone twice?
    2. Can the second file from point 6 only be flashed without flashing the file from point 1 in your answer?
  4. McJader
    Marshmallow May 18, 2021
    McJader , May 18, 2021 :
    Yes, it erases all data.
    No, you need to install the rollback build first
  5. J1618124028614
    got it, did that
    and now i cant see any pictures or videos in my gallery
    there are files in the DCIM folder but can view the older pictures in the gallery
    only the new ones when clicked are showing up in gallery
  6. McJader
    Did what?
    Yes,as I told you,it erases all data.
  7. J1618124028614
    first i flashed the beta ROM and then the stable one
    then i restored my backup files into my phone
    but i cant view the photo files in gallery
  8. McJader
    Through which method did you restore them?
  9. J1618124028614
    i sent the files from my phone to my pc, then after flashing i sent the files from pc to phone [using anydesk]
  10. Z1612187578731
    Gingerbread May 18, 2021
  11. McJader
    Hmm, so you can see these pictures in file manager but not in gallery?
  12. J1618124028614
    McJader likes this.
  13. Z1612187578731
    Gingerbread May 19, 2021
  14. G_S._R._odFS
    Cupcake May 28, 2021
    G_S._R._odFS , May 28, 2021 :
    Hi guys, I`ve rolled back before many times but yesterday I had the "wise" idea to try lineageOS cos it had android 11 but also, I got some bugs and wanted to go back to OOS 10. Any idea of the procedure? I`ve spent half day with a bricked phone to restore it to LineageOS again...so no clue for now how to rollback to oxygenOS frankly... no option for local update here...
  15. bgatewood
    bgatewood , May 28, 2021 :
    Thanks so much for instructions and file links. So disappointed with OnePlus after moving to OOS 11. Phone performance after upgrade was worse than my 5 year old Motorola. Never had to downgrade a device before so I was very anxious. Backed up all data to Google Cloud using OnePlus Switch. The only issues I experienced were...
    1. Restoring backup on beta build, it got stuck reinstalling apps. Showed "Installing 1 of 126" for several minutes. I was able to stop the update and reboot and it picked up where it was and completed update.
    2. Call log was not restored from OnePlus Switch backup. Although it says it backs up call history, the call history was empty. I had another call log backup from SMS Backup & Restore that was on my Google Drive and was created the previous day, so I lost one day of call history by restoring this one.
    One Plus 7 Pro appears to be back to original performance.
  16. ShreyasPatil_
    Jelly Bean May 28, 2021
    ShreyasPatil_ , via OnePlus 8T , May 28, 2021 :
    You should have updated OnePlus switch app before restoring the data.
  17. Ashish Agrawal007
    Cupcake Jun 14, 2021
    Ashish Agrawal007 , Jun 14, 2021 :
    I have oneplus 7T Pro 8-256, Will your downgrade package work on my phone?
