How to save battery on Resurrection remix rom?
  1. The_Rock90 Jelly Bean Jul 15, 2018
    The_Rock90, Jul 15, 2018 :
    I tried it with Franco kernel, but it drains the battery faster.
    The battery is draining much faster nowadays on my RR rom.
    If someone has knowledge to save battery, kindly inform.
  2. idkwhoiam322 Nougat Jul 15, 2018
    idkwhoiam322, Jul 15, 2018 :
    Nothing will magically save your battery. See what's draining it, probably wonky wakelocks from badly designed apps, and block them.
    Paschfire likes this.
  3. Paschfire KitKat Aug 12, 2018
    Paschfire, Aug 12, 2018 :
    Install Better Battery Stats from PlayStore and see what is draining your battery, then adjust your usage and/or system settings accordingly.​
